how to reset cisco router 1841 password
malai.joseph
Hava cisco router 1841 forgot user name and password and need to reset it to its factory setting pls help
tried boot while holding ctrl and break get into rommon1>
rommon1>confreg 0*2142
rommon1>reset
still shows rommon 3>
pls help,it ask user name and password and cant remember both
thx
J
2 Accepted Solutions
Raju Sekharan
You need to boot the router after that.
Type boot from the rommon if you have set the boot variable correctly
Hi Joseph,
Please execute the below command on the rommon prompt again,
rommon>confreg 0x2142 (not confreg 0*2142)
rommon>reset
Please see the regular process to reset the password on 1841 Router below,
  • Connect the console cable to Router 1841
  • Use the power switch in order to turn off the router, and then turn the router back on
  • Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON
  • Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash
          This step bypasses the startup configuration where the passwords are stored
  • Type reset at the rommon 2> prompt.
          The router reboots, but ignores the saved configuration.
  • Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
  • Type enable at the Router> prompt.
  • You are in enable mode and should see the Router# prompt.
  • Type copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
Important:
Do not type copy running-config startup-config or write. These commands erase your startup           configuration.
  • Type configure terminal
  • Type #enable secret <password> in order to change the enable secret password.
  • Type config-register #config-register 0x2102
  • Type write memory or #copy running-config startup-config in order to commit the changes
Refer:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_password_recovery09186a0080094773.shtml
If you couldnt boot the device after execute the below commands,
rommon>reset
As Ivan suggested, please try to boot the image from flash or bootflash where you stored the actual IOS image
rommon>boot (Boot the first image in flash memory)
rommon>boot flash:[filename] (Boot the first image or a specified image in flash memory)
rommon>boot <filename> tftpserver (Boot the specified image over the network from the specified TFTP server (hostname or IP address)
example: rommon>boot <image name> 172.16.30.40
If this doesnt work, you can recover the System Image (tftpdnld)
Note: Use the tftpdnld command only for disaster recovery because it can erase all existing data in flash memory before it downloads a new software image to the router.
Before you can enter the tftpdnld command, you must set the ROM monitor environment variables.
Prerequisites
Connect the TFTP server to a fixed network port on your router.
rommon 16 > IP_ADDRESS=171.68.171.0
rommon 17 > IP_SUBNET_MASK=255.255.254.0
rommon 18 > DEFAULT_GATEWAY=171.68.170.3
rommon 19 > TFTP_SERVER=171.69.1.129
rommon 20 > TFTP_FILE=c2600-i-mz.120-7.T.bin
rommon 21 > tftpdnld
After the tftpdnld procedure is complete, the router goes back to a ROMmon prompt.
Issue the confreg 0x2102 command and reset. If the confreg 0x2102 command is not issued, the router boots to ROMmon mode after the reset
rommon1>confreg 0x2102
rommon2>reset
Refer:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon.html
https://supportforums.cisco.com/docs/DOC-2340
Aru
Regards, Aru *** Please rate if the post useful ***
18 Replies 18
Raju Sekharan
how to boot that correctly pls?
sorry just ticked on correct answer wrongly?
still need ans
Since the router is in ROMMON after reset, it means the autoboot failed. Likely router cannot find the image.
Do you know where it is located? Use "dev" command in ROMMON mode to see file systems, then "dir ..." to list the files in each of them and boot with correct image manually using "boot ...".
     dev
     dir :
     boot :
PS: please capture console logs from the terminal when working this steps. In case of some issues it will help to find the problem.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Joseph,
As Ivan said, it failed to auto boot after you gave reset from rommon prompt. I would like to confirm you one more thing, did you try to execute * or x
I mean, 0*2142 or 0x2142
Aru
0*2142
Hi Joseph,
rommon>reset
Important:
Refer:
rommon>reset
Prerequisites
rommon2>reset
Refer:
Aru
After the following command
you need to press ctl-z to signify the end of the commands before you can write this back to memory using
Hi, i have an 1812 rooter, and i want to reset him but i don't have password and i can't reset him because the rommon mode was blocked, how can i reset rooter without rommon mod ?
You can try this section, if that doesnt work not sure
Recovering a Device from the No Service Password-Recovery Feature
To recover a device once the No Service Password-Recovery feature has been enabled, use the telnet client only (SSH is not supported). This telnet client is capable of breaking out of the current session by pressing “Ctrl+]” keys together to arrive at the “telnet>” prompt. At this prompt, you can send multiple strings of “send break” during the “#####” boot up window followed by the “Self decompressing the image :” message. You must send five to seven strings of “send break” during the break out session to arrive at the “Do you want to reset the router to factory default configuration and proceed [y/n] ?” prompt. Answer “yes” for the device to boot with the factory default configuration. If Putty client is used for the telnet session, use the break command from the drop down menu. For SecureCRT client with telnet session, press the “Ctrl +break” keys on the full keyboard. The router will not go into ROMmon mode during this recovering process.
If you do not confirm the Break key action, the router boots normally with the No Service Password-Recovery feature enabled.
Examples
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_cfg/configuration/15-sy/sec-usr-cfg-15-sy-book/sec-no-svc-pw-recvry.html
Hi Aru,
this is what happened,what next?
rommon 2 > dev
Devices in device table:
        id  name
    flash:  external compact flash
bootflash:  boot flash
    eprom:  eprom
j
get the following output
dir bootflash:
rommon 1 > dir bootflash:
monitor: command "dir" not found
Please get the following output
rommon 1 > ?
