04-08-2014 06:24 AM - edited 03-07-2019 07:01 PM
Hi - I'm not exactly new to networking but this question will likely say otherwise :)
I'm trying to figure out the command to show the running-config of a VLAN. The goal is to see if an ip helper-address has been configured on a VLAN.
This is both for a Cisco 6509 and Nexus 5k.
I simply don't know all the commands for VLANs so I can't get this info presented to me.
Thank You in advance
Solved! Go to Solution.
04-10-2014 06:29 AM
please post the output of 'show ip int brief' on both devices. Also tell us the VLAN ID its for.
04-08-2014 06:38 AM
try this command
sh ip int vlan 100 (where 100 is your VLAN id.)
you will get some like
Helper address is 172.27.1.1
04-08-2014 07:00 AM
Thanks for the prompt reply! Still no bueno though.
On the 6509 I get the following:
6509#show ip interface vlan xxx
% Invalid input detected at '^' marker.
On the Nexus 5K I can't complete the command, stops down at show ip interface with the following listed as ? after interface:
5K# show ip interface ?
<CR>
> Redirect it to a file
>> Redirect it to a file in append mode
A.B.C.D Display interface for local IP address
brief Display summary of IP interface status and configuration
ethernet Ethernet IEEE 802.3z
loopback Loopback interface
mgmt Management interface
operational Display only interfaces that are administratively enabled
port-channel Port Channel interface
vrf Display per-VRF information
| Pipe command output to filter
04-08-2014 07:02 AM
04-08-2014 07:10 AM
On the 6509 you can do "show run interface vlan X" and look for the helper-address command.
On the N5K's you can do the same but look for "ip dhcp relay address x.x.x.x"
Hope this helps
04-08-2014 10:34 AM
On 65 series the output will look like this
Hostname#sh run interface vlan XX (command to used in enable mode)
Building configuration...
Current configuration : 292 bytes
interface Vlan10
ip address X.X.X.X 255.255.255.0
ip helper-address X.X.X.X
on NX device the output will look like below
sh run interface vlan XXX (command to used in enable mode)
Hostname# sh run interface vlan XXX
!Command: show running-config interface Vlan132
interface VlanXXX
no shutdown
ip address XX.XX.XX.X/24
ip dhcp relay address XX.XX.XX.XX
04-10-2014 06:14 AM
Thanks - for some reason on either device this command doesn't work. My guess is because the vlan doesn't actually have any IP or IP helper-address assigned to it.
04-10-2014 06:29 AM
04-11-2014 06:19 AM
yeah, the VLAN in question doesn't have any IP related config to it. so it's not showing up in any of these commands.
will now add the IP address and helper address so it will be a layer 3 VLAN also.
Thanks everyone!
04-10-2014 10:20 AM
please paste the sh run configuration. so that we can help you further
10-28-2021 12:06 AM
Use this command , to check helper-address status for all SVIs
Switch#sh ip helper-address
Interface Helper-Address VPN VRG Name VRG State
Vlan10 10.100.1.10 0 None Unknown
Vlan15 10.100.1.10 0 None Unknown
Hope this helps
