How to separate 2 networks on cisco 1721 with vlans on wic
Hello!
I have 1721 with wic-4-esw and onboard ethernet. Is it possible to have 2 vlans,
one that is configured on 4 ports of wic-4-esw and other on the onboard fastethernet. Is it possible to route these vlans with eigrp without trunk port.
The idea is that i configure interface vlan 1 with ip address 192.168.2.1
Than assigne fastehernet range 1-4 to vlan 1.
Then I configure int vlan 2 with IP 192.168.3.1 and assigned Fastetheret 0 to vlan 2.
If I configure eigrp with 192.168.0.0 will these networks be connected
Re: How to separate 2 networks on cisco 1721 with vlans on wic
Hi Fisko,
I believe fastether0 interface is a layer 3 interface on router itself so its not possible to assign it to some vlan.
Rest you can create "interface vlan 1" on your esw card and assign it an ip address 192.168.2.1/24 and then assign all 4 ports to vlan 1.
You can configure fast0 interface also with an ip address 192.168.3.1/24.
Check the sh ip route and you should see them as directly connected route on your router. If that does not work then reply back and I will update you with a workaround.
Ankur
yes, it is possible to route between two VLAN without any trunk port. In this case you need to have 2 links between router and switch. One link will carry one VLAn and second link will carry another VLAN.
Config will look like this:
Router#configure terminal
Router(config) interface fa0
Router(config-if) desc *** Connecting SW1 fa0/1 ***
Router(config-if) ip address 192.168.2.1 255.255.255.0
Router(config) interface fa1
Router(config-if) desc *** Connecting SW1 fa0/2 ***
Router(config-if) ip address 192.168.3.1 255.255.255.0
SW1# config t
SW1(config) int fa0/1
SW1(config-if)desc *** Connected to Router0fa1 ***
SW1(config-if) switchport mode access
SW1(config-if) switchposrt access vlan 1
SW1(config) int fa0/2
SW1(config-if)desc *** Connected to Router fa1 ***
SW1(config-if) switchposrt access vlan 2
Router(config)#ip routing
Router(config)#router eigrp
Router(config-router)#network 192.168.0.0
Router(config-router)#no auto-summary
once done, check status of all interfaces and also check routing table to see if routes are there or not.
hope it helps ..... rate if it does ...
Hi Sourabh,
WHY do you need to have a routing protocol when the 2 interfaces are directly connected on router?
I believe the original poster wants to make sure if he can communicate between 2 networks using eigrp which is not required if he has the 2 networks defined on same router.
Ankur
Hi Ankur,
you are right that we don't need routing protocol to run as both will be directly connected networks. I thought that poster want to know that how the config will look like if he want to run EIGRP.
sorry for the confusion.
Well You are right... directed connected network should see each other without eigrp (i need eigrp to connect these networks to other side over WAN WIC) but my problem is when i configure VLAN 1 interface and give the ip to vlan interface and assigne 4 port to vlan....when i configure other ip on fastethernet 0 i get line up protocol down i can not see that network on fastethernet0.
you can't create vlan interfaces on router. you need to assign IPs to fast ethernet interface of router.
can you post the config you have put on the switch/router?
interface FastEthernet0
interface FastEthernet1
no cdp enable
switchport access vlan1
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
no cdp enable
interface Vlan1
eigrp 20
network 192.168.0.0
instead of creating vlan1 interface, please assign IP to fastethernet interface.
no cdp enable
now this router fa0 and fa1 will be connected to layer 2 switch and you will create layer 2 vlans on this switch ... correct me if I am wrong.
you need to assign vlan membership to the layer 2 switchports from which PCs will be connected.
Hi Fisko,
Is anything connected on your fastethernet 0 interface. You need to connect it to some switch or what you can do is take a cable and connect one port on your esw to your fasteherhernet 0 interface and assign that port on esw to vlan 2.
Ankur
Yes, PC is connected to fasteth0.....
I dont have a switch that's why I use 4esw wic.
you have connected PC to fa0 and line protocol is down that's why you can't see the route in that interface.
can you check connectivity between PC and router fa0, make sure you are using correct cable. Once your fa0 interface is UP, then you will be able to see the route.
hope it helps ... rate if it does ...
420
