How to set more detail logging for CISCO 2960
researchinfo
My server reported event 1123. It seems to relate to switch. Need to know how to set more detail logging for the switch to see if there is any packets loss
stephen.stack
Level 4
Level 4
Look at the interface stats on the switch for the server ports,
Show interface fa0/1
FastEthernet0 is up, line protocol is up
Hardware is Lance, address is 0060.3ef1.702b (bia 0060.3ef1.702b)
115331 packets input, 27282407 bytes, 0 no buffer
Received 93567 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
143782 packets output, 14482169 bytes, 0 underruns
0 output errors, 1 collisions, 5 interface resets
0 babbles, 0 late collision, 7 deferred
0 lost carrier, 0 no carrier
perhaps you have a routing issue, or perhaps you have errors on
your switch ports, bad cable etc ....... need more information on your setup.
You can monitor a port on a switch via a span session:
http://www.cisco.com/warp/public/473/41.html
You can use various debug commands; see here http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sea/command/reference/debug.html
HTH - Please rate if it does.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
