how to setup HSRP for Redundany
mahesh18
Level 6
Level 6
Hi all
i have this home network
Router connected to ISP is doing NAT.
Router is connected to layer 3 switch on subnet 192.168.5.1.
Layer 3 switche  has 3 vlans 10,20, and 30 to each layer 2 switch.
DHCP is config on each Vlans.
i am getting one new layer 3 switch for this network.
is this possible with new switch i can run hsrp with existing layer 3 switch?
if yes how can i do that for redundancy?
thanks
mahesh
Mahesh
Ahh okay.
So you need to -
1) connect the 2 L3 switches together using a L2 trunk
2) for each vlan you need 3 addresses eg.
vlan 10 = 192.168.5.0 255.255.255.0
192.168.5.1 =virtual ip
192.168.5.2 = sw1 SVI
192.168.5.3 = sw2 SVI
SW1
int vlan 10
ip address 192.168.5.2 255.255.255.0
standby 10 ip 192.168.5.1
standby 10 priority 110
standby 10 preempt
standby 10 auth
SW2
int vlan 10
ip address 192.168.5.3 255.255.255.0
standby 10 auth
Jon
9 Replies 9
Jon Marshall
Mahesh
It is possible but how are things connected to your L3 switch at the moment ? If you have PCs with one connection to the existing L3 switch then HSRP won't benefit you much.
Jon
hi jon
thanks for reply
i want to set us for Cisco switching exam
to learn how hsrp works
thanks
mahesh
Mahesh
Ahh okay.
So you need to -
SW1
int vlan 10
standby 10 preempt
standby 10 auth
SW2
int vlan 10
standby 10 auth
Jon
Hi jon
Thanks for reply
right now vlan 10 has ip 192.168.10.1
vlan 20 has 192.168.20.1  and vlan 30 has 192.168.30.1  on sw1.
and all 3 vlan ips are Default gateway for 3 layer 2 switches.
you mean to say i should find 3 valid ips in each vlan range?
mahesh18 wrote:
Hi jon
Thanks for reply
Mahesh
You already have one of the addresses ie. 192.168.10.1, 192.168.20.1, 192.168.30.1 so you just need another 2 IPs.
Jon
Hi Jon,
I have attached the config file of layer 3 switch
I am getting  Second layer 3 switch
so in order to have hsrp running on both please let me know what config changes will be on new switch
thanks
mahesh
Hi jon,
Many thanks again.
today i config my switch b for HSRP Lan redundancy successfully
mahesh
Wassim Aouadi
Level 4
Level 4
I guess you'll configure your new L3 switch with the aforementioned VLANs.
One way I can think of is to have both L3 switches participate in HSRP on the 3 vlans. For each vlan, one switch will be Active while the other will be Standby.
for example, for vlan 11, swA will be the Active, and swB will be the Standby:
on swA:
int vlan 11
standby 1 ip ...
standby 1 priority 150
on swB:
int vlan 11
standby 1 ip ..
standby 1 prioriry 100 (this line can be omitted since the default priority is 100).
Hi Thanks for reply
so you mean to say  new switch layer 3 can have same config as of working layer switch?
any new config which i need on  new layer 3 switch.
thanks
mahesh
