How to setup routing on switch
I have 1 networks managed by me (10.13.24/24). The servers in this network are backedup via a different network (193.28.206.0) that is not managed by me.
Currently we have a persistent static route setup in our servers. We are having problems with the route not working properly.
I want to know how do I setup routing on the switch side? Is it possible?
Using C3650G-48TS switch (C3560-IPBASEK9-M), Version 12.2(35)SE1)
Re: How to setup routing on switch
you can enable routing within the global configuration mode with commands
1 router rip/igrp/eigrp/ospf
then
2 network 10.0.0.0
3 network 192.0.0.0
it should work
I did:
1 configure terminal
2 router rip
I got an error "IP routing not enabled"
Hall of Fame Super Blue
From config mode on your 3560
3560(config)# ip routing
Then carry on with your rip configuration.
Jon
OK
give a commands ip routing in config terminal mode
then follow the previous steps
Abbas, Jon,
Thanks. The command worked fine.
But, I am still not able to see the route getting effective from my server end. When I do a tracert to the 193.28.206 address, it goes through the default gateway and not through the route created in switch.
How do I verify that the command I gave is effective on the switch?
Could you provide some more details ie.
1) Do your server backup using separate NIC's or through the same NIC as the data.
2) Could you provide the config of your switch.
3) Could you provide the static route that you used on your servers.
Jon
1. No. Backup runs with the same NIC and same IP address as it is accessed for other applications.
2. Attached switch config
3. "route.exe add 193.28.206.0 mask 255.255.255.0 10.13.25.201 -p" --> This is what is added on the servers.
Okay assuming 10..13.25.201 is reachable from your switch which it should be you can add a static route to your switch
ip route 193.28.206.0 255.255.255.0 10.13.25.201
With this an IP routing enabled you could remove your RIP configuration because it isn't doing anything for you.
Jon
Jon,
I did this and routing works fine from the switch. Perfect.
But, from within the server connected to this switch, it goes through the default gateway of the NIC and not through this route enabled on the switch.
I feel I am missing something in the overall configuration somewhere. any clues?
Can you post an ipconfig from the server ?
C:\>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Lab2
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Team-Mem2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : HP NC360T PCIe DP Gigabit Server Adapter
Physical Address. . . . . . . . . : 00-1B-78-58-31-5E
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 10.13.24.164
Subnet Mask . . . . . . . . . . . : 255.255.248.0
Default Gateway . . . . . . . . . : 10.13.24.254
do show ip route and look for R on left hand side
17>show ip route
Gateway of last resort is not set
10.0.0.0/21 is subnetted, 1 subnets
C 10.13.24.0 is directly connected, Vlan25
Hall of Fame Super Silver
Janarthanan
The output of ipconfig was helpful as is the output of show ip route. I am a little surprised that the static route does not show up in the routing table.
To really understand why the server is going to the default gateway rather than to the route I believe that we would need to see the output of route print from the server. Would you post that output?
Rick
Rick,
I want to avoid giving the static route on the server end and that's why I was checking if it is possible to do it from switch.
Below is the route table from the server (and you will not see the persistent route added). This is for a test server. Below this you will find for another server which is already in backup and having static route.
Test server:
C:\>route print
IPv4 Route Table
Interface List
0x1 ........................... MS TCP Loopback interface
0x10004 ...00 1b 78 58 31 5e ...... HP NC360T PCIe DP Gigabit Server Adapter
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.13.24.254 10.13.24.164 10
10.13.24.0 255.255.248.0 10.13.24.164 10.13.24.164 10
10.13.24.164 255.255.255.255 127.0.0.1 127.0.0.1 10
10.255.255.255 255.255.255.255 10.13.24.164 10.13.24.164 10
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
224.0.0.0 240.0.0.0 10.13.24.164 10.13.24.164 10
255.255.255.255 255.255.255.255 10.13.24.164 10.13.24.164 1
Default Gateway: 10.13.24.254
Persistent Routes:
None
Another Server:
IPv4 Route Table
Interface List
0x10003 ...00 16 35 7c d4 ad ...... HP Network Team #1
Active Routes:
0.0.0.0 0.0.0.0 10.13.24.254 10.13.24.152 10
10.13.24.0 255.255.248.0 10.13.24.152 10.13.24.152 10
10.13.24.152 255.255.255.255 127.0.0.1 127.0.0.1 10
10.255.255.255 255.255.255.255 10.13.24.152 10.13.24.152 10
193.28.206.0 255.255.255.0 10.13.25.201 10.13.24.152 1
224.0.0.0 240.0.0.0 10.13.24.152 10.13.24.152 10
255.255.255.255 255.255.255.255 10.13.24.152 10.13.24.152 1
Persistent Routes:
Network Address Netmask Gateway Address Metric
I think there may be some confusion here. I believe your switch was just acting as a layer 2 switch.
Where is the default gateway 10.13.24.254 because this is not the on the 3560 switch. The 3560 will not route your packets because it is not the default gateway for your server.
So you need to either
1) Go onto the 10.13.24.254 device and add a static route for 193.28.206.0/24 as in previous post
OR
2) Make the 3560 the default gateway for the server although without knowing your topology i would not recommend this to start with.
Rick - the static route doesn't show up because my post requesting it to be added was after the post requesting a "show ip route" even though it appears before it.
Jon
368
