08-13-2007 12:01 PM - edited 03-15-2019 01:30 AM
There is a need to shut down ports on a blade before a change. Instead of shutting each port down, I want to bring the entire module down, perform change and bring the module up after my change. I prefer not to make any configuration changes to individual ports, do not want to use interface range command either. Any help is much appreciated.
Cat 6513 Switch
IOS (tm) c6sup2_rp Software (c6sup2_rp-PK2SV-M), Version 12.1(23)E2, RELEASE SOFTWARE (fc1)
Module to shutdown:
WS-X6516-GE-TX
Khader
Solved! Go to Solution.
08-13-2007 12:37 PM
If you want power down the module,
You can view this, http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a00801026f8.html#wp1047369
into the paragraph: power enable.
I hope this is your objective.
Best regards.
Massimiliano.
08-13-2007 12:27 PM
hw-module module (mod #)
But, I think the Interface-range command with a Shut, no shut, would be safer. Even though it has been rare to happen, I have done this command on a single module and have had the switch loose adjacency with other routers for a second or two. The 6500 reconnected back very quickly, but it was long enough for some of our clustered servers to failover.
I suspect that the rebooting of the module takes a lot of processing time away from the sup engine.
08-13-2007 12:37 PM
Best regards.
Massimiliano.
