How to span port on WS-C3750G-48TS
I want to monitor a port on this switch (gig 1/0/9) to port 1/0/48. I don't seem to have the option.
WS-C3750G-48TS 12.2(25)SEE C3750-IPBASEK9-M
nj34ex07e2s41b(config)#port ?
load-balance Load Balancing metho
1 ACCEPTED SOLUTION
Re: How to span port on WS-C3750G-48TS
Hi, bedevere
The correct command to use is "monitor session" under configuration mode.
Here is a configuration guide from cisco site.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225sea/3750scg/swspan.htm
SSLIN
Hi, bedevere
SSLIN
"monitor session" is the command which you where exactly looking in for.
You are using a wrong command to setup the monitor session on the 3750 switches. The command that you are trying to use was used on earlier 3500XL switches. 3750 switches has different set of commands for port montioring. Do the folloiwng:
Config t
monitor session source interface gig 1/0/9 - 1/0/48 both <-- there is a spance between the port ranges and the - sign
montior session destination interface gig 1/0/x <- X is the port number where montior PC is connected.
Please see the link below for more information and command refrences..
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swspan.htm
HTH,Please rate if it does.
-amit singh
568
