how to tell what ports are used for connecting two stackable 3750 switches
Is there a command that shows which uplink ports are used for connecting two stackable 3750 switches together?
Thanks.
_ Greg
1 ACCEPTED SOLUTION
 Hi , Below command should do
Hi ,
 Below command should do your requirement
show switch stack-ports
Table 5-4 Commands for Displaying Stack Information
Command
Description
show platform stack manager all
Display all stack information, such as the stack protocol version.
show platform stackports {buffer | history}
Display the stack port events and history.
show switch
Display summary information about the stack, including the status of provisioned switches and switches in version-mismatch mode.
show switch stack-member-number
Display information about a specific member.
show switch detail
Display detailed information about the stack ring.
show switch neighbors
Display the stack neighbors.
show switch stack-ports[summary]
Display port information for the stack. Use the summary keyword to display the stack cable length, the stack link status, and the loopback status.
show switch stack-ring activity[detail]
Display the number of frames per member that are sent to the stack ring. The detail keyword displays the number of frames per member that are sent to the stack ring, the receive queues, and the ASIC.
Sandy
Hi ,
Command
Description
show switch
show switch detail
Sandy
Thank you much...
Thank you much...
34
