11-18-2011 09:42 AM - edited 03-07-2019 03:28 AM
On my router and switches i assigned IP address to loopback interfaces.
I do no have any tacacs server is there any way i can access the router using loopback IP address?
MAhesh
Solved! Go to Solution.
11-18-2011 10:12 AM
It's an IP address on the device(in your case). You need to reach that IP address(via routing protocol or static route etc). All configuration on vty lines are the same.
F.e
interface loopback 99
description Management IP
ip add 99.99.99.99 255.255.255.255
HTH,
Toshi
11-18-2011 09:47 AM
As long as you can reach loopback's ip address you will still access the router via that IP address. Tacacs is a part of AAA components. You can use local user/line to authenticate users as well. No need to use tacacs till you want to.
HTH,
Toshi
11-18-2011 10:08 AM
Hi Toshi,
Right now i am able to telnet router -- by IP address assigned to Fast interface.
I have also set up user name and pw.
but i was wondering if i can telnet the router using loopback IP ?
For normal telnet we do line vty 0 15
and config the telnet
But for Loobback interface i do not know how cani config it?
11-18-2011 10:12 AM
F.e
HTH,
Toshi
11-18-2011 07:34 PM
Hi Toshi,
I understand your reply.
Thanks for help again
regards
mahesh
