Webcast-Catalyst9k
How to test Local SPAN on switch
is there a way to see if my SPAN config is running OK without connecting sniffer? something in the CLI?
this is my config:
Switch#sho mon
Session 2
Type                   : Local Session
Source Ports           :
    Both               : Gi1/0/6
Destination Ports      : Gi1/0/2
    Encapsulation      : Native
          Ingress      : Disabled
1 ACCEPTED SOLUTION
I never heard of anything like that, but maybe it is just me.
However if you don't connect anything to your destination port there is nothing to check as there will be no traffic replicated to that port. If on the contrary you connect something you might check interfaces stats to see if counters move. But at this stage you might have already connected a pc with wireshark.
Riccardo
Re: How to test Local SPAN on switch
Hi Jacob,
no, you really need to connect something on your destination port and sniff the traffic.
Riccardo
hi riccardo,
i saw something somewhere about using some CLI commandsto  compare input and output rates on both ports.
but i didnt really undetstand what to check.
THANKS
Riccardo
i was looking to check if the SPAN config was the problem or the sniffer was not configured properly
248
