08-08-2014 02:37 PM - edited 03-07-2019 08:20 PM
I have two 3750x switches stacked together on floor #1, and I need to add a brand new 2960 switch on floor #2, can I do Etherchannel among them to provide redundancy for floor #2 via patch panel. I am thinking to install a patch panel on floor #2 and provide a trunk cable between 2 floors. Then using two ports on floor#2 switch to create a Etherchannel and link them to my 3750 switch on floor #1.
scenario will be this...
where === means two cat6 cable, ---- means one cat 6 cable.
2960 ==> patch panel on floor 2 (two cat6 from 2960 to p/p)
(two trunk cable from p/p#2 to p/p#1 on floor 1)
patch panel floor 2====patch panel floor 1
(one patch cord to master switch, one patch cord to member)
patch panel floor 1 --- 3750 Master switch
patch panel floor 1 ---- 3750 member switch
Solved! Go to Solution.
08-08-2014 05:39 PM
I do not see any limitation on your set up, as long as you match the configuraion, duplex and speed on the 3750 stack and the 2960 this should work just fine. Somtehing like the below config can work:
3750
interface Port-channel1
switchport mode trunk
end
interface GigabitEthernet1/0/1
channel-group 1 mode on
interface GigabitEthernet1/0/2
2960
interface Port-channel2
end
interface GigabitEthernet1/1
channel-group 2 mode on
interface GigabitEthernet1/2
Hope this helps
08-08-2014 05:39 PM
3750
end
2960
end
Hope this helps
08-08-2014 08:48 PM
thanks!
If I am not using 2960 Catalyst switch, but using Cisco small business switch like model SG200-26FP. If this configuration work?
08-10-2014 08:27 AM
I'm not really familliar with small business switches however, I understand that they support LACP therefore I would say that it will work but using LACP instead of mode on.
