How to upgrade 4507R-E sup engine from WS-X4516-10GE to WS-X45-SUP8-E
Hello, we would like to upgrade the sup engine for 4507R-E from WS-X4516-10GE  to WS-X45-SUP8-E with redundancy.
   can you provide the procedure to upgrade sup engine with minimum downtime?
Thanks.
current IOS Version 12.2(40)SG
4507#sh module
Chassis Type : WS-C4507R-E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                                       Model
 1    18  1000BaseX (GBIC)                                WS-X4418-GB
 2    48  10/100/1000BaseT (RJ45)                    WS-X4548-GB-RJ45
 3           Supervisor
 4     6   Sup V-10GE 10GE (X2), 1000BaseX (SFP)  WS-X4516-10GE
 5    48  10/100/1000BaseT (RJ45)                    WS-X4548-GB-RJ45
 6    48  10/100/1000BaseT (RJ45)                    WS-X4548-GB-RJ45
Mod  Redundancy role     Operating mode      Redundancy status
 3   Standby Supervisor     SSO                 Disabled
 4   Active Supervisor        SSO                  Active
1- Plan for MW.2- Take config
1- Plan for MW.
2- Take config backup from the box.
3- If you have spare chasis make sure the new sup's are working fine and it has the exact software on it.
4- Bring down the chasis.
5- Remove the old Sup and install the new sup.
6- Power up the chasis
7- Apply the config back on the box
8- Unshut all the ports.
 Thank you for your reply
Thank you for your reply insharie.
 Will the backup config works on new IOS or do i need to modify config?
Current IOS version : (cat4500-ENTSERVICESK9-M), Version 12.2(40)SG
Current ROMMON   : ROM: 12.2(31r)SG3
WS-X45-SUP8-E IOS and ROMMON ( by data sheet)
Software Requirements
The Cisco Catalyst 4500E Series Supervisor Engine 8-E is supported only in Cisco IOS Software and is not supported in the Cisco Catalyst Operating System Software. The minimum software version is:
Supervisor Engine 8-E, Cisco IOS XE Software Release IOS XE 3.3.0XO
ROMMON Release Notes for the WS-X45-SUP8-E
Current Release: 15.1(1r)SG4—June 29, 2014
This publication describes the new ROMMON image from on the WS-X45-SUP8-E switch.
This document consists of these sections:
Config would work fine.No
No changes required.
But make sure you unshut all the layer 3 vlans and interfaces as applying config would not automatically bring the ports up by default.
Inayath
227
