how to upgrade cat 6500
Hi all, if I want to upgrade the IOS on my cat 6500, do I just do it like normal switch, copy tftp flash ?
also, would this apply to both CPU's? or would I need to upgrade each independently?
also when I save config on the active CPU, does this automatically apply to the standby cpu ?
Bronze
Re: how to upgrade cat 6500
Hello Carl,
A how to is found here
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801347e2.shtml
From what I rememeber you need to upgarde both sups seperately. However bootflash statements will be synchronised and so for the second sup you can just copy the image across and reload ie
copy bootflash:xxx slavebootflash:xxx
Bronze
Oh yeah - and yes configs are synchronised between the sups.
You can run commands on the secondary sup with
remote command standby-rp
or
remote login standby-rp
and check running/startup config, bootvar, config-register etc.
Hall of Fame Super Gold
Depends on the IOS you want: Mono or Modular.
288
