09-16-2013 03:19 PM - edited 03-07-2019 03:30 PM
Hi All,
My client has a HPc7000 chassis. It has 4 Cisco 48 gig switch blades. I found that it is running on very old IOS.
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1) witch
Switch Ports Model SW Version SW Image
* 1 24 WS-CBS3020-HPQ 12.2(37)SE1 CBS30X0-LANBASE-M
I want to upgrade IOS all four blades IOS. Can you please provide me guidance. I have never seen these switches before. Do I have to upgrade each switch IOS randomly or it work like a 3750 stackable switches, so I can upgrade IOS from HP GUI interface and all switches will be upgraded. I couldnt find any 0documentation about how to upgrade HP c7000 switch chassis. Please advice
Solved! Go to Solution.
09-16-2013 03:37 PM
Same as a standalone switch. Don't look at it as a "stacked" 3750. The only similarities to a 3750 is the IOS.
When you upgrade, you have three choices:
1. Copy the BIN files (not recommended but is "do-able");
2. Use the "archive tar /x" (not recommendable if you don't know what you are doing); or
3. Use the "archive download-sw tftp:
I'd recommend you use option #3.
Please don't forget to rate our useful posts.
09-16-2013 03:39 PM
BIG F@T WARNING:
Before you even TRY or ATTEMPT to start the upgrade process, make sure you compare the MD5 hash value of your IOS file that you've already download against the MD5 hash value found in the Cisco website.
If you're MD5 hash value DO NOT MATCH, then you need to re-download the file again.
If you're MD5 hash value don't match and you push this IOS into your switch, your switch will, potentially, not boot.
09-16-2013 03:37 PM
09-16-2013 03:39 PM
BIG F@T WARNING:
09-16-2013 03:40 PM
Freak me. That was fast. I haven't even finish posting my last comment.
Thanks for taking the time to rate our posts.
09-16-2013 03:44 PM
Thanks Leo, I was waiting for answer :-)
I was actually confused because HP C7000 switch new to me and it has four Cisco 48port gig switch blades. It is in data center cage. Thanks for confirming that I can upgrade each switch as a standalone and it has nuthing to do with HP GUI mode.
Current system image file is "flash:cbs30x0-lanbase-mz.122-37.SE1/cbs30x0-lanbase-mz.122-37.SE1.bin"
I will download Tar file. Thanks a lot for your help.
09-16-2013 03:46 PM
The blade is sold by HP but "made by" Cisco. The IOS is hosted by Cisco and not in HP systems.
Another thing ... What IOS version are you trying to upgrade to?
09-16-2013 03:55 PM
I just checked on cisco web site and found that new version is IP base and I have old lan base. I have just picked latest version from downlod list.
IP BASE cbs30x0-ipbasek9-mz.122-58.SE1.bin
09-16-2013 03:59 PM
I wouldn't touch this version. No-way-Jose.
Go with 12.2(55)SE8 instead.
12.2(58)SE is one of the bad/worst IOS versions I've ever encountered with. And besides, this version was released back in May 2011. I wouldn't call it "new".
09-16-2013 04:12 PM
Ah thanks.. I didnt know that. Thanks for saving my life.
09-16-2013 04:15 PM
ROFL!
No problem. Now you have some knowledge your colleagues can be jealous of.
