How to Use BPDU Guard
If I run RSTP, I don't need to run PortFast. However, to run BPDU guard, I need to turn on PortFast on every single port? Does PortFast override RSTP's native fast port convergence? I just don't want to turn on PortFast (more config for me to do) and I just want to enable BPDU guard globally. Is it possible to use BPDU guard without configuring PortFast on the interface? Thank you.
1 ACCEPTED SOLUTION
Gold
Re: How to Use BPDU Guard
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml#edge
Look under the definition for EDGE port.
One of those strange things that happen when cisco has a solution before everyone else jumps on board. Sorta like cisco using the work native to mean untagged in 802.1q
Silver
Hi ,
As of 7.2 of 6500 switch ,you can can set bpdu-guard on individual ports. Regardless of the the global bpdu-guard setting, if you enable bpdu-guard on individual ports and receive a bpdu, the port will errdisable. In the older 6.x code you had been running, this only worked with portfast enabled. As of 7.2, you can enable this on a per port basis without portfast.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_2/cmd_ref/setsn_su.htm#1243604
Hope it helps you.
satish
Thank. I only run IOS on my switches. I have
2950
2970
3500XL
3550
3560
3750
5500
4500
6500
What IOS version do I need for each platform so that I don't need to enable portfast for BPDU guard to work? Thanks.
hi as far as i know you can use BPDU gaurd on the RSTP enabled port and it will not take away the properties of RSTP on it.....
only RSTP features will be disabled if it is connected to a switch which cannot understand RSTP... then the port becomes STP....please let me know the results.
Hope it helped you.... please rate all the ratings....
Gold
Maybe i am missing something but why do you not have portfast on all you access ports.
The only way for a switch to know which are edge ports when running RSTP is to have this configured. You are removing one of the very nice features of RSTP since all port that are not edge ports will cause topology change notification to be sent to the root bridge everytime a use boots his PC.
RSTP does not really use the concept of portfast but cisco uses this keyword to mean EDGE port.
Cisco terminology is very confusing. As we all know, Portfast is Cisco proprietary protocol. I thought Portfast functionality is already built into RSTP and that's why I thought I don't need to enable portfast on the Edge Port. Is it true or am I wrong? If it is true that RSTP doesn't have portfast feature built into the protocol, I need to enable portfast on every switch and every platform?
Gold
1106
