How to view logs on Cisco 7600 router
sarahr202
Level 5
Level 5
HI everybody
I need to chcek the logs for a  customer  for a particular inteface ( it flapped but need to find out when and thus my  serach for logs)
Our platform is
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 15.1(3)S5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 12-Feb-13 13:17 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp
thanks
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It depends on device configuration.  If device is configured for local syslogging, show log should show log contents.
If device is configured to send to an external syslog, you should be able to see log entries there.
kozorezdi
I guess you are looking for the command to see the event into syslog.
"This example shows how to enable the system logging of the interface state-change events on all interfaces in the system:
Router(config)# logging event link-status default
Dmitry
Joseph W. Doherty
Disclaimer
Posting
kozorezdi
Dmitry
