How upgrade ws-c3750G-48TS-S??
can you please help me to upgrade my new ws-c3750G-48TS-S to ful dynamic IP routing?
thank you for your help
3 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
1.  Do you have the license to upgrade to IP Services feature set?
2.  Post the output to the command "sh version".
Here you will good understanding of IOS service for your switch hardware
http://www.cisco.com/en/US/products/hw/switches/ps5023/index.html
The Cisco Catalyst 3750 is available with two software images:
  • IP Base software includes advanced quality of service (QoS), rate limiting, access control lists (ACLs), Open Shortest Path First (OSPF) for routed access, and IPv6 functionality.
  • IP Services software provides a broader set of enterprise-class features, including advanced hardware-based IP Unicast and IP Multicast routing, as well as policy-based routing (PBR).
Santhosh Saravanan
HTH Regards Santhosh Saravanan
License is not needed for this switches as it is only required for E and X switches (3750X/3750E).  If you are entitled to download the IP Services image software, that can provide you the full routing features you are looking for.
Thank you every one for your response.
I don't have the License, do i need license for this upgrade??
Super Bronze
Re: How upgrade ws-c3750G-48TS-S??
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Legally, yes.
Santhosh Saravanan
i have download this version does this support OSPF??
Thank you in advance.
IP Services feature set will support OSPFv2 and OSPFv3.   IP Base will only support OSPFv1.
Just want to remind you that you didn't purchase any license or right-to-use the IP Services feature set.
EDIT:  IP Base will support OSPFv2 but you have a single process only.  If you want more, IP Services is your next port of call.
Leo,
It will support OSPFv2. Recall, the OSPFv1 was a prototype and apart from ancient Proteon and GATED implementations, no vendor has actually released a commercial implementation. I do not believe Cisco ever supported OSPFv1 in IOS.
Best regards,
Peter
The IP Base feature set supports OSPF for routed access to enable customers to extend Layer 3 routing capabilities to the access or wiring closet. The IP services feature set is required if you need multiple OSPFv2 and OSPFv3 instances without route restrictions.
Found in New Software Features.
Disregard this.
VIP Super Bronze
Leo,
That statement regarding OSPF version-1 is very confusion, as I have never seen any Cisco device that can be configured with OSPF version-1 or any one has actually deployed it. I think, the ment ver-2, but they never removed it form the data sheet.
Reza
Reza, Peter,
I'm getting confused here.  Mea Culpa.
I think what I meant to say is IP Base will support OSPFv2 with single process only.
Hi Leo,
I've gone over the document - there is no mention of OSPFv1 in particular. The document sometimes uses the term OSPF without referring to a version but to me, that does not implicate the version 1.
Best regards,
Peter
Peter,
To early in the morning and not enough caffine in my IV drip.
I've edited my earlier posts.
Hi Leo,
Hey, it was not serious at all... just unexpected. Regarding the caffeine, I'd rather choose a couple more hours to nap (if possible of course).
Best regards,
Peter
Serious for me.  How many times have you pointed this out?  A lot.  Not funny for me.
Unfortunately, you're an instructor.  You're not allowed to take naps while teaching class.
Super Bronze
Disclaimer
Posting
Are you saying a Cisco "paper" feature license is no longer required for original 3750 series to run IP Services?  Or, are you just saying the original series doesn't have an on-board license enablement/control feature as do the later E and X series?
Hi Mendez,
If no need license, is that this version can support OSPF:c3750me-i5k91-mz.122-55.SE.bin?
Thank you very much
Won't work.  Your 3750 will boot into ROMmon because you are using an IOS file for a different switch model, a 3750 Metro Ethernet.
700
