HP Flex-10 and VSS
I am having a strange problem where we have HP Vconnect having connection to Cisco 6509-E with VSS and configured with port-channels, now everyday the port channels start fluctuating for 4-5 minutes and gets stablize after that or if some does manual reset. below is the configuration...what could be the issue? is there anyone else who has faced this problem?
for primary chassis------------------------
interface Port-channel101
switchport
switchport mode trunk
lacp fast-switchover
interface TenGigabitEthernet1/3/1
switchport
channel-protocol lacp
channel-group 101 mode active
interface TenGigabitEthernet1/3/2
switchport
---------------for secondary chassis----------------------------------------------
interface Port-channel103
switchport
interface TenGigabitEthernet2/3/1
switchport
channel-group 103 mode active
interface TenGigabitEthernet2/3/2
switchport
VIP Super Bronze
HP Flex-10 and VSS
I am not sure why you have configured 2 different Portchannels (101 and 103) on a VSS pair? Both chassis are logically one device and in this case there should be only one Portchannel.  Can you try using the same Portchannel and test again?
HP Flex-10 and VSS
Port-Channel 101 connects TenGig 1/3/1 & 1/3/2 to one VC of Enclosure 1 and Port-Channel 103 connects TenGig2/3/1 & 2/3/2 to second VC of Enclosure 1 with LACP. Do you suggest to connect them without port-channel or combined TenGig1/3/1 & TenGig2/3/1 into single port channel?
541
