Community Member
HSRP active and standby having issues
I just moved my config from a 5505 to a 6509 (IOS) and my HSRP is not working. One of the 6509 is suppose to be the active for group 1, and standby for group2. Now all active are on 1 6509 and all standby are on the other.
Attached is the output of show standby.
I have a fibre link between both 6509 switches with vlan all set on it to see if it would fix it. So far no luck.
Any help or suggesitons would be appreciated.
All groups are assigned to VLAN interfaces.
1 REPLY
Community Member
Re: HSRP active and standby having issues
Problem fixed.. both were set to equal priority on one of the groups. Silly cut and paste got me there..
141
