HSRP and ip
I've configured the following on my 3560 switch. But if I plug in pc on a port and run a ping to say 10.36.3.1 (vlan 1) or any of the other vlans the pings fail. the ip of the pc os 10.36.0.1. Could some one please explain to me why this is failing?
ip routing
interface Vlan1
ip address 10.36.3.3 255.255.0.0
no ip route-cache
standby 1 ip 10.36.3.1
standby 1 priority 120
standby 1 preempt
interface Vlan200
ip address 10.100.36.3 255.255.255.0
ip helper-address 10.36.1.1
no ip route-cache
standby 2 ip 10.100.36.1
standby 2 priority 120
standby 2 preempt
interface Vlan201
ip address 10.101.36.3 255.255.255.0
no ip route-cache
standby 3 ip 10.101.36.1
standby 3 priority 120
standby 3 preempt
Thanks in advance
Dan
Purple
Re: HSRP and ip
You should be able to ping vlan 1 but unless you have at least one active port in the other vlans the layer 3 interface will not be active and you won't be able to ping those.
Hall of Fame Super Silver
Re: HSRP and ip
Dan
I am not clear from your post whether the PC was able to access other things - for example could it ping the physical interface address - or was the only problem in ping to the virtual address? Also what VLAN was the port assigned to that the PC connected to? Perhaps you can clarify this for us.
Rick
Re: HSRP and ip
Hi Dan,
What is the status of the VLAN interfaces, are they UP/UP, in order to have them up, you need at least one port connected in the respective VLAN or an active trunk port.
HTH,
Mohammed Mahmoud.
Silver
Re: HSRP and ip
Hi Dan ,
Please paste " show vlan " and "show int " for better understanding of vlan status and ports assigned to valns..
Cheers :
Satish
116
