Webcast-Catalyst9k
HSRP and STP Issue in Nexus 7K
I am facing issues in inconsistencies between two Nexus 7K. Nexus1 and Nexus2 are connected with VPC fabricpath and NonVPC as well.
HSRP on Nexus1 for VLAN 97 is not getting its standby(Nexus2) however Nexus2 is getting its active(Nexus1).
Below are the configuration & issues.
Nexus1:
vlan 97
  mode fabricpath
interface Vlan97
  no ip redirects
  ip address 10.30.6.60/27
  no ipv6 redirects
  ip ospf passive-interface
  ip router ospf 100 area 0.0.0.100
  hsrp version 2
  hsrp 97
    authentication md5 key-string edn
    preempt
    priority 120
    ip 10.30.6.62
  no shutdown
interface port-channel90
  description vPC+ peer-link
  switchport
  switchport mode fabricpath
  vpc peer-link
interface port-channel51
  description Non_vPC_LINK
  switchport
  switchport mode trunk
  switchport trunk native vlan 4
  switchport trunk allowed vlan 730,734
  spanning-tree port type network
spanning-tree vlan 97 priority 0
interface port-channel115
switchport trunk allowed vlan 97
vpc 115
 sh spanning-tree vlan 97
VLAN0097
  Spanning tree enabled protocol rstp
  Root ID    Priority    97
             Address     c84c.75fa.6000
             This bridge is the root
             Hello Time  2  sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    97     (priority 0 sys-id-ext 97)
Interface        Role Sts Cost      Prio.Nbr Type
Po115            Desg FWD 200       128.4210 (vPC) P2p Peer(STP)
sh hsrp interface vlan 97
Vlan97 - Group 97 (HSRP-V2) (IPv4)
  Local state is Active, priority 120 (Cfged 120), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 120
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 0.702000 sec(s)
  Virtual IP address is 10.30.6.62 (Cfged)
  Active router is local
  Standby router is unknown
  Authentication MD5, key-string "edn"
  Virtual mac address is 0000.0c9f.f061 (Default MAC)
  7 state changes, last state change 01:15:04
  IP redundancy name is hsrp-Vlan97-97 (default)
Some Logs:
%STP-2-BRIDGE_ASSURANCE_BLOCK: Bridge Assurance blocking port port-channel51 VLAN0097
 %STP-2-L2GW_BACKBONE_UNBLOCK: L2 Gateway Backbone port inconsistency cleared unblocking port port
-channel115 on VLAN0097
Nexus2:
vlan 97
  mode fabricpath
interface Vlan97
  no ip redirects
  ip address 10.30.6.61/27
  no ipv6 redirects
  hsrp version 2
  hsrp 97
    preempt
    ip 10.30.6.62
  no shutdown
  switchport
  vpc peer-link
interface port-channel4051
  switchport
spanning-tree vlan 97 priority 8192
vpc 115
VLAN0097
  Root ID    Priority    8289
  Bridge ID  Priority    8289   (priority 8192 sys-id-ext 97)
  Local state is Standby, priority 100 (Cfged 100), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 100
  Next hello sent in 0.212000 sec(s)
  Active router is 10.30.6.60, priority 120 expires in 1.002000 sec(s)
  Standby router is local
  11 state changes, last state change 00:32:16
  Some Logs:
-channel51 on VLAN0097.
Appreciate your support.
Anser
VIP Super Bronze
Hi,I am not familiar with
I am not familiar with fabicpath, but I don't see vlan 97 in your vpc-peerlink. (po90).
Also, is vpc peerlink up and running?
sh vpc
have you tried removing authentication for vlan 97 on both switches?
What is the output of "sh run vpc"?
What device is vpc primary?
Hi,Nexus1 is primary in VPC
Nexus1 is primary in VPC role. See the below output as required from Nexus 1:
sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1000
vPC+ switch id                    : 1000
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
vPC fabricpath status             : peer is reachable through fabricpath
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 5
Peer Gateway                      : Enabled
Peer gateway excluded VLANs       : -
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
Fabricpath load balancing         : Disabled
Port Channel Limit                : limit to 244
vPC Peer-link status
id   Port   Status Active vlans
1    Po90 up     16-22,24-27,30-34,96-98
how running-config vpc
!Time: Mon Apr 28 08:25:19 2014
version 6.1(4a)
feature vpc
vpc domain 1000
  role priority 1000
  peer-keepalive destination 172.x.x.x source 172.x.x.x vrf vpc-keepalive
  peer-gateway
  auto-recovery
  fabricpath switch-id 1000
  vpc 115
  vpc peer-link
I am not getting an authentication issues.
Anser
Adding one point that port
Adding one point that port-channel 115 is between Cisco 3750 and Nexus 7K (Nexus 1 & 2) and this is the path to reach the servers.
What is the purpose of Po51 /
What is the purpose of Po51 / Po4051 and why is it not a vPC when you're running the switches in vPC+ mode?
My guess from the log messages would be that you haven't configured "spanning-tree pseudo-information" such that the FP cloud is the root for all VLANs and acts as a single logical switch to the non-FP world.
Cisco FabricPath Best Practices provides an excellent checklist for FP implementation.
547
