HSRP authentication not working between 2 switches
mahesh18
Level 6
Level 6
Hi Everyone,
HSRP was working fine between 2 switches.
I config authen on vlan 20 on switch A
Switch A
3550SMIA#sh run int vlan 20
Building configuration...
Current configuration : 261 bytes
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip ospf hello-interval 40
standby 1 ip 192.168.20.3
standby 1 priority 150
standby 1 preempt delay minimum 60
standby 1 authentication md5 key-chain mahesh
standby 1 track FastEthernet0/11 60
Vlan20 - Group 1
  State is Active
    2 state changes, last state change 7w2d
  Virtual IP address is 192.168.20.3
  Active virtual MAC address is 0000.0c07.ac01
    Local virtual MAC address is 0000.0c07.ac01 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.968 secs
  Authentication MD5, key-chain "mahesh"
  Preemption enabled, delay min 60 secs
  Active router is local
  Standby router is unknown
  Priority 150 (configured 150)
    Track interface FastEthernet0/11 state Up decrement 60
  IP redundancy name is "hsrp-Vl20-1" (default)
Switch B
3550SMIB#     sh run int vlan 20
Current configuration : 200 bytes
interface Vlan20
ip address 192.168.20.2 255.255.255.0
Vlan20 - Group 1
  State is Active
    2 state changes, last state change 00:28:06
    Next hello sent in 2.400 secs
  Priority 100 (default 100)
Vlan30 - Group 2
There is layer 2 and layer 3 IP connectivity between two switches
Both switches have ospf running between them.
Bothe switches are reporting as active.
MAhesh
3 Accepted Solutions
Richard Burts
Mahesh
It would appear that there is a problem with the authentication that you configured using key chain mahesh. But you have provided no information for us about this key chain. So our ability to find the issue is quite limited. Additional information, especially about the key chain would be most helpful.
Rick
Rick
Karthick Murugan
Hi Mahesh,
I guess you have not defined the Key-Chain. Please look at the same configuration below.
key chain mahesh
key 1
   key-string cisco
A
Current configuration : 129 bytes
interface Vlan40
ip address 40.1.1.1 255.255.255.0
standby 1 ip 40.1.1.3
end
B
interface Vlan40
en
sh standby bri
                     P indicates configured to preempt.
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Vl40        1    100   Active  local           40.1.1.1        40.1.1.3
Hope it helps
Karthick Murugan
Thanks & Regards, Karthick Murugan CCIE#39285
Mahesh,
I am really glad that the issue is resolved.
To answer your question, if you are using Key chain based authentication, you need to configure a key without which the authentication wouldn't work. However, you can configure more than 1 key with more than 1 key-string and you have an option to choose a specific key for specific duration.
If you wish to include just the MD5 password then the configuration will look like this below and it doesn't require key-chain/key configuration.
interface Vlan40
standby 1 authentication md5 key-string mahesh
Karthick Murugan
CCIE#39285(R&S)
7 Replies 7
Richard Burts
Mahesh
Rick
Rick
Hi Rick,
I have this config under both switches.
sh key chain mahesh
Key-chain mahesh:
do i need to add below config also--
key 1
   key-string cisco
I will try those and will update you.
MAhesh
Karthick Murugan
Hi Mahesh,
key chain mahesh
key 1
   key-string cisco
A
interface Vlan40
end
B
interface Vlan40
en
sh standby bri
Hope it helps
Karthick Murugan
Hi KArthick,
I have this key chain config  on both switches
#sh key chain mahesh
Key-chain mahesh:
Will add full key chain config and will update you.
MAhesh
Hi Rick & Karthick,
So adding full key chain config
key chain mahesh
key 1
   key-string cisco
fixed the issue.
just need to know why we need key 1 and key-string  cisco configured  on both switches?
so it means when we enable hsrp authen then single config og key chain mahesh will not work?
MAhesh
Mahesh,
interface Vlan40
Karthick Murugan
CCIE#39285(R&S)
Hi KArthick,
Many thanks for great explanation.
Best regards
MAhesh
