Community Member
HSRP between 3750 & 3650
Pls help me, is it possible to implement HSRP between Cat 3750 & 3650 switches.
Thanks in advance.
Re: HSRP between 3750 & 3650
Yes, you can, but please use Cisco Feature Navigator to use a feature set that supports HSRP for each platform.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Community Member
Thnx for reply. small clarification, 3650 is Layer2 or Layer3?
I guess you mean 3560 not 3650, and yes it is a layer 3 switch.
Mohammed Mahmoud.
Layer3 but the exact features depend upon the licence,
BASE == Static routing
SERVICE = Dynanic Routing
ADVANCE SERVICE == IP6 Routing
505
