06-02-2008 10:05 PM - edited 03-05-2019 11:22 PM
How can I add the HSRP config to a VLAN interface option.
06-02-2008 10:10 PM
This is how you could do it :
Interface Vlan 10
ip add x.x.x.x y.y.y.y
standby 1 ip x.x.x.x
standby 1 preempt
standby 1 priority 150
HTH,
-amit singh
06-02-2008 10:30 PM
interface Vlan5
ip address x.x.x.x 255.255.252.0
standby priority 60
standby 1 ip y.y.y.y
standby 1 priority 60
standby 1 preempt
x.x.x.x = physical Ip on interface
y.y.y.y = Virtual Ip (used as gateway for hsots on vlan)
Priority = Higher priority switch is active
Preempt = Causes the switch to takeover the active state when its priority is higher than other switch.
06-02-2008 11:14 PM
Thanks ... I will try it should work.
06-03-2008 04:57 PM
Hi Narayan,
The default priority value is 100 and why did you choose the 60 as priority, why not 5 or 100 or 200 or 500 ?
Thanks and Regards
06-03-2008 11:26 PM
I think the other poster choose the priority 60 in order to make this router as a standby and the other as active.If u leave the priority for default u will not have the control over election of standby and active routers.
Mahmood
06-04-2008 05:35 PM
Thanks Mahmood.
