Webcast-Catalyst9k
HSRP dupplicate addres issue
We had a power faliure in our company last week, which resulted in a lot of problems on our network, we managed to braing everything back to life, theres just one more problem that we cant solve:
We have two 2811 routers working in HSRP, they are connected both deirectly and to two stacked c2960s switches that go on to the rest of the network. Since the faliure we keep getting messages like these on both routers:
Sep 26 07:27:03.626: %IP-4-DUPADDR: Duplicate address 10.251.214.201 on FastEthernet0/1, sourced by 0023.5e07.e0b9
Sep 26 07:32:03.631: %IP-4-DUPADDR: Duplicate address 10.251.214.41 on FastEthernet0/1, sourced by 0023.5e07.e0b8
Sep 26 07:27:13.485: %IP-4-DUPADDR: Duplicate address 10.251.214.43 on FastEthernet0/0, sourced by 0023.5e07.e058
We have been researching the problem and found a lot of ppl who had similar problems, buth all were caused by different things (loops, viruses, NAT, DHCP), and none of them seem to fit our situation, the most baffling thing about this is that other than these messages being generated every 30 seconds there are no other indications of the problem, everything seems to be working and all configurations are the same as they were before the power faliures, if our monitoring department werent complaining about recieving a bunch of alerts we wouldnt even bother with this
Below this im posting relevant configurations, if any1 has some ideas please help!
The configurations of the two routers are:
rtr101:
interface Port-channel1
switchport access vlan 112
switchport mode trunk
interface FastEthernet0/0
description Customer O&M Uplink 1
ip address 10.251.214.41 255.255.255.128
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
standby 102 ip 10.251.214.40
standby 102 preempt
standby 102 track Vlan112
interface FastEthernet0/1
description Customer Production Uplink 1
ip address 10.251.214.201 255.255.255.224
ip nat outside
duplex auto
speed auto
standby 103 ip 10.251.214.200
standby 103 preempt
standby 103 track Vlan128
interface FastEthernet1/0
description svr101:mgt
spanning-tree portfast
interface FastEthernet1/1
description svr101:nge0
channel-group 1 mode on
interface FastEthernet1/2
description svr101:nge1
interface FastEthernet1/3
description rtr102:fa1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
description "local connector to traffic LAN"
switchport access vlan 128
interface FastEthernet1/7
description "local connector to OAM LAN"
interface FastEthernet1/8
shutdown
interface FastEthernet1/9
shutdown
interface FastEthernet1/10
shutdown
interface FastEthernet1/11
shutdown
interface FastEthernet1/12
shutdown
interface FastEthernet1/13
shutdown
interface FastEthernet1/14
shutdown
interface FastEthernet1/15
shutdown
interface Vlan1
no ip address
interface Vlan112
description O&M LAN
ip address 172.31.112.7 255.255.252.0
ip nat inside
standby 112 ip 172.31.112.1
standby 112 preempt
standby 112 track FastEthernet0/0
interface Vlan128
description FE LAN
ip address 172.31.128.7 255.255.252.0
ip nat inside
standby 128 ip 172.31.128.1
standby 128 preempt
standby 128 track FastEthernet0/1
interface Async0/0/0
description Terminalserver-Port svr102:con
no ip address
encapsulation slip
interface Async0/0/1
description Terminalserver-Port rtr101:con
no ip address
encapsulation slip
interface Async0/0/2
no ip address
encapsulation slip
interface Async0/0/3
no ip address
encapsulation slip
interface Async0/0/4
no ip address
encapsulation slip
interface Async0/0/5
no ip address
encapsulation slip
interface Async0/0/6
no ip address
encapsulation slip
interface Async0/0/7
no ip address
encapsulation slip
router rip
version 2
redistribute connected
redistribute static metric 5
passive-interface default
no passive-interface FastEthernet0/1
network 169.254.0.0
distribute-list prefix RIPv2-Out out
distribute-list prefix RIPv2-In in
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.251.214.1
ip route 10.12.2.100 255.255.255.255 10.251.130.1
ip route 10.12.4.41 255.255.255.255 10.251.130.1
ip route 198.18.16.1 255.255.255.255 198.18.100.254
ip route 198.18.16.2 255.255.255.255 198.18.100.254
ip route 198.18.16.3 255.255.255.255 198.18.100.254
no ip http server
no ip http secure-server
ip nat inside source static 172.31.112.7 10.251.214.41
ip nat inside source static 172.31.112.8 10.251.214.42
ip nat inside source static 172.31.112.128 10.251.214.43
ip nat inside source static 172.31.112.129 10.251.214.44
ip nat inside source static 172.31.113.128 10.251.214.45
ip nat inside source static 172.31.113.129 10.251.214.46
ip nat inside source static 172.31.128.128 10.251.214.47
ip nat inside source static 172.31.128.129 10.251.214.48
ip nat inside source static 172.31.129.32 10.251.214.201
ip nat inside source static 172.31.129.33 10.251.214.202
ip access-list standard SNMP-ACL
ip prefix-list RIPv2-In description Things we listen to via RIPv2
ip prefix-list RIPv2-In seq 5 deny 0.0.0.0/0 le 32
ip prefix-list RIPv2-Out description Things we publish via RIPv2
ip prefix-list RIPv2-Out seq 5 deny 0.0.0.0/0
ip prefix-list RIPv2-Out seq 999999 permit 0.0.0.0/0 le 32
logging facility local5
logging 172.31.112.128
logging 172.31.112.129
rtr102:
interface Port-channel2
description Customer O&M Uplink 2
ip address 10.251.214.42 255.255.255.128
ip nat outside
duplex auto
speed auto
standby 102 priority 95
standby 102 preempt
description Customer Production Uplink 2
ip address 10.251.214.202 255.255.255.224
ip nat outside
duplex auto
speed auto
standby 103 priority 95
standby 103 preempt
description svr102:mgt
description svr102:nge0
channel-group 2 mode on
description svr102:nge1
description rtr101:fa1/3
shutdown
shutdown
no switchport
no ip address
shutdown
no switchport
no ip address
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
no ip address
interface Vlan112
description O&M LAN
ip address 172.31.112.8 255.255.252.0
ip nat inside
standby 112 priority 95
standby 112 preempt
interface Vlan128
description FE LAN
ip address 172.31.128.8 255.255.252.0
ip nat inside
standby 128 priority 95
standby 128 preempt
no ip address
encapsulation slip
no ip address
encapsulation slip
no ip address
encapsulation slip
no ip address
encapsulation slip
no ip address
encapsulation slip
no ip address
encapsulation slip
no ip address
encapsulation slip
no ip address
encapsulation slip
router rip
version 2
redistribute connected metric 11
redistribute static metric 11
network 169.254.0.0
no auto-summary
no ip http server
ARP tables of both routers:
rtr101#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.251.214.1           31   0000.0c07.ac04  ARPA   FastEthernet0/0
Internet  10.251.214.2           31   0026.cafb.76c1  ARPA   FastEthernet0/0
Internet  10.251.214.3           31   0026.cafb.7ec1  ARPA   FastEthernet0/0
Internet  10.251.214.10          30   34bd.c819.3641  ARPA   FastEthernet0/0
Internet  10.251.214.40           -   0000.0c07.ac66  ARPA   FastEthernet0/0
Internet  10.251.214.41           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.42           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.43           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.44           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.45           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.46           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.47           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.48           -   0023.5e07.e058  ARPA   FastEthernet0/0
Internet  10.251.214.193         31   0026.0b31.11be  ARPA   FastEthernet0/1
Internet  10.251.214.196         31   0050.56ac.0008  ARPA   FastEthernet0/1
Internet  10.251.214.197         31   0050.56ac.000b  ARPA   FastEthernet0/1
Internet  10.251.214.198         31   0050.56ac.0008  ARPA   FastEthernet0/1
Internet  10.251.214.199         31   0050.56ac.0008  ARPA   FastEthernet0/1
Internet  10.251.214.200          -   0000.0c07.ac67  ARPA   FastEthernet0/1
Internet  10.251.214.201          -   0023.5e07.e059  ARPA   FastEthernet0/1
Internet  10.251.214.202          -   0023.5e07.e059  ARPA   FastEthernet0/1
Internet  172.31.112.1            -   0000.0c07.ac70  ARPA   Vlan112
Internet  172.31.112.7            -   0023.5e07.e058  ARPA   Vlan112
Internet  172.31.112.8           31   0023.5e07.e0b8  ARPA   Vlan112
Internet  172.31.112.128          0   0021.28ff.b3ee  ARPA   Vlan112
Internet  172.31.112.129          0   0021.28ff.b32e  ARPA   Vlan112
Internet  172.31.113.128         31   0021.28ff.b3f2  ARPA   Vlan112
Internet  172.31.113.129         31   0021.28ff.b332  ARPA   Vlan112
Internet  172.31.114.32           1   0021.28ff.b3ee  ARPA   Vlan112
Internet  172.31.114.33           1   0021.28ff.b32e  ARPA   Vlan112
Internet  172.31.128.1            -   0000.0c07.ac80  ARPA   Vlan128
Internet  172.31.128.7            -   0023.5e07.e058  ARPA   Vlan128
Internet  172.31.128.128          0   0021.28ff.b3ee  ARPA   Vlan128
Internet  172.31.128.129          0   0021.28ff.b32e  ARPA   Vlan128
Internet  172.31.129.32           4   0021.28ff.b3ee  ARPA   Vlan128
Internet  172.31.129.33           4   0021.28ff.b32e  ARPA   Vlan128
rtr102#sh arp
Internet  10.251.214.4           14   009c.02a7.24d8  ARPA   FastEthernet0/0
Internet  10.251.214.12           1   0050.56ac.0007  ARPA   FastEthernet0/0
Internet  10.251.214.13          16   0050.56ac.000a  ARPA   FastEthernet0/0
Internet  10.251.214.41           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.42           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.43           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.44           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.45           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.46           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.47           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.48           -   0023.5e07.e0b8  ARPA   FastEthernet0/0
Internet  10.251.214.201          -   0023.5e07.e0b9  ARPA   FastEthernet0/1
Internet  10.251.214.202          -   0023.5e07.e0b9  ARPA   FastEthernet0/1
Internet  172.31.112.7           31   0023.5e07.e058  ARPA   Vlan112
Internet  172.31.112.8            -   0023.5e07.e0b8  ARPA   Vlan112
Internet  172.31.114.33           0   0021.28ff.b32e  ARPA   Vlan112
Internet  172.31.128.8            -   0023.5e07.e0b8  ARPA   Vlan128
Internet  172.31.128.128          1   0021.28ff.b3ee  ARPA   Vlan128
Internet  172.31.129.33           0   0021.28ff.b32e  ARPA   Vlan128
Switch interfaces to which the routers are connected:
interface GigabitEthernet1/0/44
description AAA Management to rtr101 fa0/0
switchport access vlan 543
switchport mode access
interface GigabitEthernet1/0/45
description AAA Production to rtr101 fa0/1
switchport access vlan 546
interface GigabitEthernet2/0/44
description AAA Management to rtr102 fa0/0
interface GigabitEthernet2/0/45
description AAA Production to rtr102 fa0/1
Thank you for reading,
regards
137
