ā12-07-2013 01:16 PM - edited ā03-07-2019 04:58 PM
Hi Everyone,
I am trying to config HSRP tracking ip route on Switch 3550A.
Switch 3550A and B are running HSRP on vlan 20.
Switch 3550A has next hop to Router.
Below is my config on 3550A
track 11 ip route 172.31.3.0 255.255.255.0 metric threshold
threshold metric up 61 down 62
3550SMIA#sh run int vlan 20
Building configuration...
Current configuration : 257 bytes
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip ospf hello-interval 40
standby 1 ip 192.168.20.3
standby 1 priority 150
standby 1 preempt delay minimum 60
standby 1 track 11 decrement 60
3550SMIA#sh track 11
Track 11
IP route 172.31.3.0 255.255.255.0 metric threshold
Metric threshold is Down (no route)
1 change, last change 00:08:19
Metric threshold down 62 up 61
First-hop interface is unknown
Tracked by:
HSRP Vlan20 1
3550SMIA#sh ip route 172.31.3.0
Routing entry for 172.31.3.0/24
Known via "ospf 1", distance 110, metric 300, type extern 2, forward metric 1
Last update from 192.168.5.3 on FastEthernet0/11, 3w5d ago
Routing Descriptor Blocks:
* 192.168.5.3, from 4.4.4.4, 3w5d ago, via FastEthernet0/11
Route metric is 300, traffic share count is 1
Need to know why it is showing Metric threshold is down and first hop int is unknown?
MAhesh
Solved! Go to Solution.
ā12-08-2013 07:56 AM
Try adding this to your track statement and see what happens. Put it ahead of the entry of the route itself .
track 11 interface f0/11 ip routing
ā12-07-2013 01:50 PM
Hi Mahesh,
This is quite strange. At first, it seems to me to be a bug of some sort... I wonder: if you created another track object, say, 12, and referred to the very same route 172.31..3.0/24, would it also say that the route is unreachable? I am trying to find out if the track object 11 is "stuck" for any reason.
Best regards,
Peter
ā12-07-2013 04:29 PM
Hi Peter,
I did not create any other track object that points to same route.
so you agree that my config is correct?
3550SMIA# sh track
Track 11
1 change, last change 03:35:04
Tracked by:
HSRP Vlan20 1
MAhesh
ā12-07-2013 11:42 PM
Hi Mahesh,
Yes, I agree that your configuration is correct. I would have done it quite in the same way. However, I actually want you to create another track object that refers to the same route I want to see if the other object complains about the same issue as your track object 11.
Best regards,
Peter
ā12-08-2013 05:04 AM
Hi Peter,
I created another track object as below
3550SMIA(config)#track 12 ip route 172.31.3.0 255.255.255.0 metric threshold
3550SMIA#sh track
Track 11
1 change, last change 00:00:55
Metric threshold down 255 up 254
Tracked by:
HSRP Vlan20 1
Track 12
1 change, last change 00:00:13
Seems it did not complain.
Seems as it is not seeing route in routing table even thogh route exists thats the reason it is taking the interface down right?
Mahesh
ā12-08-2013 05:37 AM
Hi Mahesh,
This is getting even stranger. I wonder - if you tried clear ip route * or clear ip ospf process to renew the contents of the routing table, would the track objects and their states change? Please note that these commands will cause temporary interruption in your traffic so do this only if there is no important traffic being routed right now, and allow for up to 10 seconds for the connectivity to recover.
If this does not help then I believe you should try upgrading the IOS, as this smells very strongly as an IOS bug.
Best regards,
Peter
ā12-08-2013 06:18 AM
Hi Peter,
I did clear ip ospf process still same thing.
Also the IOS which i have is latest what cisco has.
3550SMIA# sh inventory
PID: WS-C3550-24PWR-SMI
3550SMIA# sh flash
Directory of flash:/
2 -rwx 9707290 Mar 25 2010 16:37:50 -06:00 c3550-ipservicesk9-mz.122-44.SE6.bin
Seems nothing much more i can try now at this point.
Thanks for your help
Mahesh
ā12-08-2013 08:42 AM
Hi Glen,
Here is what i did
3550SMIA#sh run | inc track
3550SMIA#config t
Enter configuration commands, one per line. End with CNTL/Z.
3550SMIA(config)#no track 11 ip route 172.31.3.0 255.255.255.0 metric threshold
3550SMIA(config)#track 11 interface f0/11 ip routing
3550SMIA(config-track)#track 11 ip route 172.31.3.0 255.255.255.0 metric threshold
% Cannot change tracked object 11 - delete old config first
3550SMIA(config)#end
Seems system does not allow to put the second track 11 command again.
Is this default behaviour?
3550SMIA#sh track
Track 11
Interface FastEthernet0/11 ip routing
IP routing is Up
1 change, last change 00:00:34
Tracked by:
HSRP Vlan20 1
now the int vlan 20 is active for HSRP vlan 20.
sh standby shows
Vlan20 - Group 1
State is Active
14 state changes, last state change 00:02:29
Virtual IP address is 192.168.20.3
Active virtual MAC address is 0000.0c07.ac01
Local virtual MAC address is 0000.0c07.ac01 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 0.588 secs
Authentication MD5, key-chain "mahesh"
Preemption enabled, delay min 60 secs
Active router is local
Standby router is 192.168.20.2, priority 100 (expires in 8.592 sec)
Priority 150 (configured 150)
Track object 11 state Up decrement 60
Need to undertsand what difference above command makes now?
Best reagrds
Mahesh
ā12-14-2013 08:47 AM
Many thanks Glen.
MAhesh
