HSRP Flapping query
We have a setup at a customer site, whereby a Cisco 887-VA-K9 and a Cisco 887-VA-SEC-K9 are each connected to their own ADSL connections into our customers MPLS cloud.
We have HSRP running on the LAN side between these routers and the Active router (the SEC-K9) is tracking our MPLS Sponge address (10.10.10.1). The HSRP priority will drop from 110 to 80 if the tracker goes down.
The setup is as follows:
Active Config (887-VA-SEC-K9)
track 123 ip sla 1 reachability
ip sla auto discovery
ip sla 1
 icmp-echo 10.10.10.1 source-interface Dialer0
 frequency 10
ip sla schedule 1 life forever start-time now
interface Vlan1
 ip address 192.168.1.252 255.255.255.0
 ip nbar protocol-discovery
 standby 10 ip 192.168.1.254
 standby 10 priority 110
 standby 10 preempt
 standby 10 track 123 decrement 30
Standby Config (887-SEC-K9)
interface Vlan1
 ip address 192.168.1.253 255.255.255.0
 standby 10 priority 90
 standby 10 preempt
Our customer has not complained of any performance issues. However when I look at the logs of the primary I can see severe HSRP flapping.
Jun 10 13:21:16 BST: %TRACKING-5-STATE: 123 ip sla 1 reachability Up->Down
Jun 10 13:21:16 BST: %HSRP-5-STATECHANGE: Vlan1 Grp 10 state Active -> Speak
Jun 10 13:21:21 BST: %TRACKING-5-STATE: 123 ip sla 1 reachability Down->Up
Jun 10 13:21:22 BST: %HSRP-5-STATECHANGE: Vlan1 Grp 10 state Speak -> Active
Jun 10 13:36:26 BST: %TRACKING-5-STATE: 123 ip sla 1 reachability Up->Down
Jun 10 13:36:28 BST: %HSRP-5-STATECHANGE: Vlan1 Grp 10 state Active -> Speak
Jun 10 13:36:31 BST: %TRACKING-5-STATE: 123 ip sla 1 reachability Down->Up
Jun 10 13:36:34 BST: %HSRP-5-STATECHANGE: Vlan1 Grp 10 state Speak -> Active
My understanding of the above config is that the Active will poll the MPLS Sponge IP at 10 second intervals using ICMP. However based on the above log, it appears that the Active router detects that a ping fails at 13:36:26 but then realizes it comes back at 13:36:31 only 5 seconds later. But if it only polls every 10 seconds, should it not be AT LEAST 10 seconds until it polls again to see that it is up?
Given the noise and line length on some of these MPLS sites, a small bit of packet loss and reduced line speed is acceptable. However I want to make sure that I fully understand how tracking works before I look at adjusting its sensitivity to perhaps allow more tolerance.
Thanks for any help in advance. :)
Everyone's tags (4)
1 ACCEPTED SOLUTION
HelloThe tracking will poll
Hello
The tracking will poll the ip sla I think every 5 sec ( not sure on this) and your sending a ping every 10 secs via ip sla
So if the sla misses a ping then the tracking will poll again before another sla ping and the tracking will kick in and down your hrsp state.
You have verified that the destination sla address is indeed reachable, so maybe try adding a delay to the tracking for the down state.
track 123
delay 30 down
res
Paul
Please don't forget to rate any posts that have been helpful. Thanks.
HelloCan you ping 10.10.10.1
Hello
Can you ping 10.10.10.1 sourced from the dialer 0 interface ?
res
Paul
Yes. The default route of the
Yes. The default route of the router is out of the dialer 0 interface. So any ping to 10.10.10.1 would go out the dialer interface and hence be sourced from it.
The question I'm asking is about the technical working of the tracking/sla configuration, rather than specific connectivity issues about this particular site.
Hello
track 123
delay 30 down
res
Paul
Hi Paul, This seems to be
Hi Paul,
This seems to be working. We have set this on a couple of affected customer sites and the flapping seems to have stopped without any adverse affect to the customers setup. I cannot see any instances of the atm interface bouncing so what I have done is clear the vdsl counters and I will monitor it over the next few days for errors.
Anyway, that's more information than needed. The information you have given was what I needed for my query. Thanks.
652
