HSRP in cisco 6500
vinoth.kumar
HI,
We have two cisco 6500 switch and i need to run HSRP for redunancy between the switch
but my query is since we have lot of VLAN created in primary switch how i can deploy the HSRP between them
whether i need to have different HSRP group for each VLAN
And if i connect the uplink from two catalyst to the distribution switch then whether i need to consider for STP
please suggest me
7 Replies 7
Tshi M
Level 5
Level 5
I had two 6500 series with multiple VLANs running HSRP. I had setup HSRP for each VLANs. I also used STP since you will be setting redundant links between your core switches (C6500) to the access layer switches.
HI
thanks for the reply
can u post me the sample config which you have deployed since iam new to HSRP and STP
Thanks in advance
I will shortly.
awaiting for your reply
Here is just a sample config that i just wrote:
Core1
spanning-tree mode pvst
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
spanning-tree backbonefast
spanning-tree vlan 30,40 priority 24576
interface Vlan30
ip address 10.20.30.2 255.255.255.0
ip helper-address 10.20.10.29
no ip route-cache
standby name Servers
standby 30 ip 10.20.30.1
standby 30 priority 110
standby 30 preempt
interface Vlan40
ip address 10.20.40.2 255.255.255.0
no ip route-cache
standby name Workstations
standby 40 ip 10.20.40.1
standby 40 priority 110
standby 40 preempt
Core 2
spanning-tree vlan 30,40 priority 28672
interface Vlan30
ip address 10.20.30.3 255.255.255.0
no ip route-cache
standby 30 priority
standby 30 preempt
interface Vlan40
ip address 10.20.40.3 255.255.255.0
no ip route-cache
standby 40 priority
standby 40 preempt
I also used uplinkfast on the access layer switches:
spanning-tree portfast default
spanning-tree uplinkfast
take a look at this link as well
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_configuration_example09186a008009467c.shtml
Was the above helpful in any way? Please rate as this helps the forum as well.
Please find my attached setup diagram and suggest me how i can go head with the STP part
since we have planned redundancy for the server in terms of two NIC card
Vinoth
