HSRP in Switch
Hi Everybody,
I am planning to configure HSRP in 3560 switch.
1. Whether the configuration will also be replicated?
2. Should i connect a dedicated cable between the switches for hello messages?
Can anybody throw light on this
R.B.Kumar
1 ACCEPTED SOLUTION
Super Bronze
Re: HSRP in Switch
#1 As far as I know, you'll need to manually configure HSRP on other gateway devices.
#2 No, but since the purpose of HSRP is to migrate gateway if the active gateway fails, you often want a L2 loop between HSRP gateways and their gateways hosts (with loop broken by spanning tree).
Bronze
Re: HSRP in Switch
1. As far as I know the switches' configurations are not replicated via HSRP.
2. You will need a cross-over between the devices.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml
Super Bronze
Re: HSRP in Switch
105
