HSRP Information Synchronization
haithamnofal
Level 3
Level 3
My understanding is that 2 routers configured for HSRP need a L2 connectivity to synchorinize their HSRP group information, so in case I am connecting the 2 routers to 2 failover firewalls directly (i.e. router A is connected to FW1 and router B is connected to FW2 and I have HSRP between Routers A and B) and there is no L2 SW in the middle, how will I be able to pass the HSRP information between the 2 routers? Can a direct link between the 2 routers pass the HSRP information?
Haitham
Richard Burts
Haitham
I am not clear whether you are talking about running HSRP between the routers on their LAN side connections (it may make good sense there) or on the router connection to the Firewall. If the router LAN connection is through a layer 2 switch it should work fine and has benefit of supplying redundant default gateway to the client PCs on the LAN. I am not clear why you would want to run HSRP on the connection to the firewalls, and since the firewalls would not pass the HSRP hello traffic, HSRP would not work there.
Perhaps you can explain your environment and what you are trying to accomplish with HSRP and then maybe we can give you better answers.
Rick
Rick
Ahmede
Small switch in between the two routers and the two firewall will do the trick..
Thanks for the replies, actually the setup is as follows:
Router A ----- FW 1----Core Switch
Router B ----- FW 2----Core Switch
If I to configure HSRP between router A and B to have my firewall cluster pointing to 1 default gateway address, the question is there a way to have this setup be achieved without a L2 SW between the routers and the firewalls (i.e. using for example a direct connection between the 2 routers for passing the HSRP traffic because I currently dont have a switch to use between the routers and firewalls)?
Haitham
Haitham,
You would need a switch in your scenario between your firewalls and the routers.
For HSRP to work, it is necessary that they exchange hellos for which they require connectivty at Layer2
HTH, rate if it does
Narayan
