HSRP Multicasts Are Flooding My Switchports
I'm studying for my CCNP Switch exam. I've set up a switch block with
two 3550s and two 2950s. I've also configured HSRP with a 200 msec
hello timer and a & 750 dead timer as per the "Campus Network for High
Availability Design Guide".
Now the PCs that are attached the the access switches are getting
hammered with HSRP messages.
How can I filter these out?
Thx
2 ACCEPTED SOLUTIONS
VIP Purple
HSRP packet woud be sent to Multicast address 224.0.0.2 on udp port 1985. So it is multicast traffic & traverse across trunk links you configured for vlans where HSRP configured. Since you have multiple trunk links between distribution (across access switches & direct distribution switches) traffic can go any path.
In your 2950 switch, is this traffic flooded to all ports (irespective of what vlan configured on it) ? This is a very old switch model & not sure this platform handle multicast traffic exactly the way we wanted.
Following links should help you as well.
Understanding and Troubleshooting HSRP Problems in Catalyst Switch
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml
HSRP: Frequently Asked Questions
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800a9679.shtml
Pls rate the response if it is useful
Rasika
Andrew,
You could see if your switch (not all of them do) support "switchport block multicast" on the port. This blocks all multicast though and is not configurable. Otherwise, depending on your setup, you could put your routers in their own vlan and then all of your users in their own vlan.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
You can check to make sure that igmp snooping is enabled on the switches. They're generally enabled by default, but may not be on yours.
show ip igmp snooping
HTH,
John
I checked the switches. IGMP snooping is enable on all of them.
Unfortunately, it seems IGMP snooping doesn't filter the HSRP multicast
traffic on 224.0.0.2
"In general, addresses from 224.0.0.1 to 224.0.0.255 are reserved... CGMP and IGMP snooping
do not work with this reserved address range."
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00800b0871.shtml
Andrew
Andrew,
HTH,
John
Re: HSRP Multicasts Are Flooding My Switchports
There's no joy in HSRP land.
Here's what I've tried:
1. Switchport Block Multicast - This certainly looks good. I tried to configure this on the trunks
at the access layer for multicast traffic entering the switch. Unfortunately, my 2950 switches
don't support this feature.
2. Storm-control Multicast Level 0 - I thought I had it with this one. I configured this on the trunks
at the distribution layer for multicast traffic leaving the switch. Unfortunately, it also filtered the
broadcast traffic.
"...when the multicast traffic rate exceeds the threshold, all incoming traffic, except
spanning-tree packets, INCLUDING BROADCAST AND UNICAST [my emphasis],
is throttled until the level drops below the specified threshold."
http://www.ciscopress.com/articles/article.asp?p=99029&seqNum=3
Conclusion: Don't set aggresive timers without newer equipment. (Switchport Block Multicast looks like the right solution).
Andrew
I forgot to include my TO DO list...
TO DO: Replace NIC that died under the strain of 2 days worth of 200 msec hello HSRP multicasts
Andrew.
VIP Purple
Rasika
764
