08-29-2014 12:59 AM - edited 03-07-2019 08:34 PM
I have HSRP configured but doesn't seem to be failing over on a failure. Below are the outputs during a failover of a cable pull and the configs.
Standby output on primary during failover, to me this shouldn't be in Active mode as the track is down.
GigabitEthernet0/1 - Group 10
State is Active
9 state changes, last state change 00:01:11
Virtual IP address is 172.168.32.1
Active virtual MAC address is 0000.0c07.ac0a
Local virtual MAC address is 0000.0c07.ac0a (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 2.272 secs
Preemption enabled
Active router is local
Standby router is 172.168.32.10, priority 80 (expires in 10.288 sec)
Priority 90 (default 100)
Track object 1 state Down decrement 10
Group name is "hsrp-Gi0/1-10" (default)
Track output from primary during failover:
Track 1
List boolean and
Boolean AND is Down
11 changes, last change 00:01:27
object 2 Down
object 3 Up
Tracked by:
HSRP GigabitEthernet0/1 10
Primary config:
track 1 list boolean and
object 2
object 3
track 2 interface GigabitEthernet0/0 line-protocol
track 3 interface GigabitEthernet0/1 line-protocol
standby 10 ip 172.168.32.1
standby 10 preempt
standby 10 track 1 decrement 10
Secondary config:
object 2
object 3
track 2 interface GigabitEthernet1/0/36 line-protocol
track 3 interface GigabitEthernet1/0/43 line-protocol
interface Vlan10
standby 10 priority 90
standby 10 preempt
08-29-2014 01:06 AM
Can you execute the following command on the secondary :
conf t
interface vlan 10
no standby 10 track1 decrement 10
08-29-2014 02:13 AM
Just would like to add to Walter said,
Try to put the following command if you dont want it to be removed:
conf t
interface vlan 10
no standby 10 track1 decrement 30
Inayath
*Plz dont forget to rate all usefull posts.
