09-24-2012 04:23 AM - edited 03-07-2019 09:03 AM
Hey all,
got a little problem with hsrp on two cisco nexus.
Configuration should be correct, but the two nexus doesn't seem to 'comunicate'.
sh hsrp group 17
Vlan17 - Group 17 (HSRP-V1) (IPv4)
Local state is Active, priority 110 (Cfged 110), may preempt
Forwarding threshold(for vPC), lower: 1 upper: 110
Hellotime 1 sec, holdtime 3 sec
Next hello sent in 0.490000 sec(s)
Virtual IP address is 172.16.17.1 (Cfged)
Active router is local
Standby router is unknown
Authentication text "cisco"
Virtual mac address is 0000.0c07.ac11 (Default MAC)
2 state changes, last state change 1w3d
IP redundancy name is hsrp-Vlan17-17 (default)
interface configuration (trunk cores)
interface port-channel1
description Core-Channel
switchport mode trunk
interface Ethernet1/1
channel-group 1 mode active
interface Ethernet1/2
VLAN17 configuration NEXUS1
interface Vlan17
no shutdown
no ip redirects
ip address 172.16.17.2/24
hsrp 17
preempt
priority 110
timers 1 3
ip 172.16.17.1
ip dhcp relay address 172.16.16.47
VLAN17 configuration NEXUS2
interface Vlan17
no shutdown
no ip redirects
ip address 172.16.17.3/24
hsrp 17
preempt
timers 1 3
ip 172.16.17.1
Thanks in advance for your help!
09-24-2012 06:23 AM
Looks like HSRP multicast is not making it across. Does Po1 connect the two Nexus 5548s? Are you able to ping physical IP address of other switch?
09-24-2012 06:51 AM
Yeah sure:
Switch_2_new(SSI15430KTP)
Eth1/1 176 S I s N5K-C5548P Eth1/1
Eth1/2 176 S I s N5K-C5548P Eth1/2
ping 172.16.1.3
PING 172.16.1.3 (172.16.1.3): 56 data bytes
64 bytes from 172.16.1.3: icmp_seq=0 ttl=254 time=3.09 ms
64 bytes from 172.16.1.3: icmp_seq=1 ttl=254 time=3.692 ms
64 bytes from 172.16.1.3: icmp_seq=2 ttl=254 time=3.751 ms
64 bytes from 172.16.1.3: icmp_seq=3 ttl=254 time=3.759 ms
64 bytes from 172.16.1.3: icmp_seq=4 ttl=254 time=3.979 ms
09-24-2012 10:59 PM
Btw: Multicast should work if CDP sees neighbours or am I wrong here?
09-25-2012 07:58 AM
Worked offline with Christian.. He has L3 modules offline due to missing license and he will try installing L3 base license and test.
02-04-2016 06:42 AM
Prashanth
Can you contact me about this issue. I have two nexus 5548's that I thought both had layer 3 when they were purchase but when I do a show mod this is the output I get.
SWITCH 1:
Mod Ports Module-Type Model Status
1 32 O2 32X10GE/Modular Universal Platfo N5K-C5548UP-SUP active *
3 0 O2 Daughter Card with L3 ASIC N55-D160L3-V2 ok
SWITCH 2:
3 0 O2 Non L3 Daughter Card N55-DL2 ok
