HSRP on 3650
I have a couple 3650 switches with IP base licenses. Is it possible to do HSRP redundancy between them? or Would I have to upgrade to IP services?
Waqas
Everyone's tags (3)
1 ACCEPTED SOLUTION
Green
HSRP on 3650
Looking at this link for 3560 config on ios 12.2.52SE  just for example
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swhsrp.html
Configuring HSRP
This chapter describes how to use Hot Standby Router Protocol (HSRP) on the Catalyst 3560 switch to provide routing redundancy for routing IP traffic not dependent on the availability of any single router. HSRP for IPv4 is supported on switches running the IP base or IP services image. To use HSRP for IPv6, see Chapter 38, "Configuring IPv6 Unicast Routing."
So you can run HSRP for IPV4 with IP BASE
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Green
HSRP on 3650
Configuring HSRP
Alex.
HSRP on 3650
Thanks Alex
2129
