Community Member
HSRP on a 6513
My question is:
How do you setup HSRP on 2 6513's without using an external Router? Is this at all possible?
12.2(18)SXF8 with SUP720 MSFC3
Community Member
Re: HSRP on a 6513
ya , its possible.Just configure secondary address and define priorty greater than defualt 1.e 110..because 100 is default.
12.2(18)SXF8 with SUP720 MSFC3 supprots HSRP..
Re: HSRP on a 6513
Here's an example
Switch 1
interface vlan 22
ip address 1.1.1.2 255.255.255.0
standby 22 ip 1.1.1.1
standby 22 priority 105
standby 22 preempt
Switch 2
interface vlan 22
ip address 1.1.1.3 255.255.255.0
standby 22 preempt
HTH, rate if it does
Narayan
Community Member
Re: HSRP on a 6513
I would consider GLBP not HSRP, GLBP allows all the hosts to be configured with the same IP address as the default gateway and still achieve redundancy and load balancin, and you won't have to add arp timeouts like I needed to do for an issue I ran into...
Consider GLBP as the next Gen of HSRP...
121
