You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
HSRP on BVI Interface
Dears
Would like your assistance please regarding below scenario
I have a server with two tagged L2 uplinks terminated on two 802.1q subinterfaces @ 2800 routers as shown in below diagram
I wish to run HSRP between both routers but as you know neither SVI nor L2 interfaces are supported on low end routers unless there is switching module inserted in router
What I have been thinking of is to use integrated bridging (irb) where to bridge both interfaces fa0/0 & fa0/1 and run HSRP on bvi interface
I did this but unfortunately HSRP was not working !
Thanks to share your comments
R1#sh standby brief
                    P indicates configured to preempt.
Interface  Grp  Pri P State  Active          Standby        Virtual IP
BV100      100  120  Active  local          unknown        100.0.0.254
R1#
_________________
Below are the configurations
R1
bridge irb
interface FastEthernet0/0
no ip address
interface FastEthernet0/0.1
encapsulation dot1Q 100
bridge-group 100
interface FastEthernet0/1
no ip address
bridge-group 100
interface BVI100
ip address 100.0.0.1 255.255.255.0
standby 100 ip 10.0.0.254
standby 100 priority 120
R2
bridge irb
no ip address
bridge-group 100
no ip address
bridge-group 100
interface BVI100
ip address 100.0.0.2 255.255.255.0
Sherif Ismail
  • LAN Switching and Routing
Everyone's tags (2)
Gold
Hi Sherif,
when you enable routing on the BVI, packets that come in on a routed interface, are taken care by the L3 BVI and in your design, there is no Layer 3 interface except for the BVI itself. BVI is a bridge between routed and bridge domain. i dont think BVI alone can do much here.
and one other thing, with regards to the diagram, you have ur sever connected to both routers, why HSRP then?
Hope it Helps,
Soroush.
Hope it Helps, Soroush.
Hi Soroush
mmm ... I believe my configuration is similar to below one except that mine have HSRP
http://cisconet.com/lanman/lan-general/552-how-to-configure-irbintegrated-routing-and-bridging.html
Can you advise an example with BVI HSRP or explain how HSRP messages will follow between both routers
Many Thanks
Sherif Ismail
Gold
Sherif, in the url u sent, there are 2 bridge ports setup PC1 and 2, and one routed port setup for PC3, so its not the same.
with regards to ur configuration, u made a switch out of ur routers. besides... if this is the exact physical setup? why do u want hsrp?
when you set HSRP, one router takes control as active and the other one as standby, so there is only one router active at a time! members of a hrsp group continuesly exchange messages, so if the active went out, the standby takes control.
but for this setup u have i dont see a reason and possibility for a HSRP env.
u might find this useful:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a91.shtml#background
Hope it Helps,
plz Rate if it helped.
Soroush.
824
