HSRP: Standby ip x.x.x.x secondary
VLAN 10 below is configured on two Cat6500 switches. Layer 2 etherchannel is running between both switches.
Can anyone explain the multiple instances of standby ip x.x.x.x secondary under vlan 10.
Colm
interface Vlan10
ip address 134.226.102.3 255.255.255.0
no ip redirects
ip flow ingress
ip pim sparse-mode
standby ip 134.226.137.2
standby ip 134.226.100.1 secondary
standby ip 134.226.100.2 secondary
standby ip 134.226.101.1 secondary
standby ip 134.226.101.2 secondary
standby ip 134.226.102.2 secondary
standby ip 134.226.103.1 secondary
standby ip 134.226.103.2 secondary
standby ip 134.226.136.1 secondary
standby ip 134.226.136.2 secondary
standby ip 134.226.174.1 secondary
standby ip 134.226.174.2 secondary
standby ip 134.226.175.1 secondary
standby ip 134.226.175.2 secondary
standby ip 134.226.190.1 secondary
standby ip 134.226.190.2 secondary
standby ip 134.226.191.1 secondary
standby ip 134.226.191.2 secondary
standby priority 120
standby preempt
standby authentication notcisco
interface Vlan10
ip address 134.226.102.5 255.255.255.0
no ip redirects
ip flow ingress
ip pim sparse-mode
standby priority 110
standby preempt
Re: HSRP: Standby ip x.x.x.x secondary
They are the virtual addresses that the clients will use as their gateway.
HTH,
John
HTH, John *** Please rate all useful posts ***
Hall of Fame Super Silver
Hello Colm,
the secondary option is allowed to instruct the switch that the VIP of that group has to be associated to a secondary ip address.
However, I think that this configuration is wrong:
a)the device should have an ip address .... secondary configured to have it to work to provide a valid source for HSRP packets and to be able to advertise the subnet.
b) I think different HSRP group numbers should be used
I think the right configuration should be something like:
int vlan 10
ip address 10.10.10.2 255.255.255.0
ip address 10.10.20.2 255.255.255.0 secondary
standby 1 10.10.10.1
standby 2 10.10.20.1 secondary
and so on
c) the primary command is in the wrong subnet
for me none of these HSRP statements are effective
if all you need is a single working HSRP group use
standby 134.226.102.x
Hope to help
Giuseppe
Thanks Giuseppe.
2897
