HSRP Tracking
Tshi M
Level 5
Level 5
Is it possible to track the interface running hsrp?
interface GigabitEthernet0/0
ip address 10.1.1.21 255.255.255.248
duplex full
speed 100
media-type rj45
negotiation auto
standby 5 ip 10.1.1.22
standby 5 priority 200
standby 5 preempt
standby 5 track Serial1/0 20
standby 5 track GigabitEthernet0/0 20
Richard Burts
Etienne
I do not believe that it is possible to track the interface itself that HSRP is running on. And if it was possible I am not sure why you would want to do this.
The purpose of tracking an interface is so that you can decrease the priority of an interface running HSRP if some other interface goes down. If the interface running HSRP goes down you do not want to decrease its priority you want the other standby interface to take completely over.
Rick
Rick
Richard Burts
Etienne
Rick
Rick
Etienne
I am glad that my answer helped to resolve your question. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read a response which resolved the question.
I encourage you to continue your participation in the forum.
Rick
Rick
Thanks for the quick reply yesterday. My concern with the current HSRP configuration is that it is only tracking our serial interface. Last week the switch module to which Gig0/0 is connected failed but the router kept working in active mode because the HSRP was not affected by the failure. We had to manually change everything.
regards,
