11-12-2009 08:49 PM - edited 03-06-2019 08:35 AM
Quick questions with hsrp can you track more than one thing at a time within the same hsrp group?
For example within one hsrp group can you have interface tracking and also ip sla tracking as well?
Ross.
Solved! Go to Solution.
11-13-2009 12:03 AM
Hello Ross,
yes this is possible.
each tracked object will produce a priority decrement if it fails.
this helps in scenarios where you want the active router to change role only when multiple events happen or if you want to track multiple aspects.
Hope to help
Giuseppe
11-13-2009 12:03 AM
Hello Ross,
Hope to help
Giuseppe
