Community Member
hsrp troubleshooting document
Can any one provide some trouble shooting documents and links :
I have a config like in router 1 and router 2
standby 2 ip 10.x.x.x
standby 2 priority 110
standby 2 preempt
standby 2 track 2
standby 2 track 3
ip sla monitor 10
type dns target-addr x.x.x.x name-server x.x.x.4
ip sla monitor schedule 10 life forever start-time now
track 2 rtr 10
track 3 rtr 10 reachability
It is a failover scenerio.
Say when router 1 fails router 2 does not take over .
What are the troubleshooting steps that I need to follow .
Thanks in advance
Raj
Silver
Re: hsrp troubleshooting document
Hi Raj ,
Track rtr command is used for tracking the state of a Cisco IOS IP Service Level Agreements (SLAs) operation , not the router.
Every IP SLAs operation maintains an operation return-code value. This return code is interpreted by the tracking process. The return code may return OK, OverThreshold, and several other return codes. Different operations may have different return-code values, so only values common to all operation types are used.
Two aspects of an IP SLAs operation can be tracked: state and reachability. The difference between these aspects relates to the acceptance of the OverThreshold return code. Table 62 shows the state and reachability aspects of IP SLAs operations that can be tracked.
Table 62 Comparison of State and Reachability Operations
Tracking Return Code Track State
State OK Up
(all other return codes) Down
Reachability OK or over threshold Up
Examples
The following example shows how to configure the tracking process to track the state of IP SLAs operation 2:
track 1 rtr 2 state
The following example shows how to configure the tracking process to track the reachability of IP SLAs operation 3:
track 2 rtr 3 reachability
THANKS,
Satish
Community Member
Hi Satish,
Thanks for ur prompt reply.
Is there any documents in cisco site that if hsrp fails in router what are the steps I need to follow.
Raj
Silver
Hi Raj ,
The config on your router is for SLA tarcking purpose , not for tarcking interfaces.
Below link may be useful for you.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8c.shtml
Satish
Community Member
Hi Satish,
Thanks for your help a lot.
For example this link has a lot of case studies was looking for something similar .
http://cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml
Raj
806
