HSRP Virtual IP not able to ping
Hello ,
   I need help to ping my virtual ip of HSRP group
First i will explain my scenario
I have  a lan with 4 switches of cisco 2960 model inter-connected with trunk links and  , then i  created 4 different vlan for e.g Vlan 10 ,20 ,30 ,40 in core switch and i populated the created vlans to all other switches using VTP. Then the core switch is connected to a 2 routers on ports Gi 0/1 and Gi 0/2 ( both the ports are trunked and encapsulated with 802.1Q , also configured the links to carry traffic of all the VLANS in the switch )
In Both the routers i created 4 subinterface one for each vlan and assigned ip address for all subinterfaces . then i created HSRP group 10 , 20 ,and  30 and 40 then assigned virtual ip's .
I canble to ping virtual ip address from the active router. but i canot able to ping the virtual ip from standby router as well as the client system .
R1#
R1#sh run
R1#sh running-config
Building configuration...
Current configuration : 1530 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 10
ip address 10.0.10.3 255.255.255.0
ip helper-address 10.0.50.5
standby version 2
standby 10 ip 10.0.10.1
interface FastEthernet0/0.2
encapsulation dot1Q 20
ip address 10.0.20.3 255.255.255.0
standby version 2
standby 20 ip 10.0.20.1
interface FastEthernet0/0.3
encapsulation dot1Q 30
ip address 10.0.30.3 255.255.255.0
standby version 2
standby 30 ip 10.0.30.1
interface FastEthernet0/0.4
encapsulation dot1Q 40
ip address 10.0.40.3 255.255.255.0
standby version 2
standby 40 ip 10.0.40.1
interface FastEthernet0/0.5
encapsulation dot1Q 50
ip address 10.0.50.3 255.255.255.0
standby version 2
standby 50 ip 10.0.50.1
interface FastEthernet0/1
ip address 20.0.0.4 255.255.255.0
duplex auto
speed auto
standby version 2
standby 1 ip 20.0.0.1
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
The below output is for R2 router
R2#
R2#sh ru
R2#sh running-config
version 12.4
hostname R2
no ip address
duplex auto
speed auto
ip address 10.0.10.2 255.255.255.0
standby version 2
ip address 10.0.20.2 255.255.255.0
standby version 2
ip address 10.0.30.2 255.255.255.0
standby version 2
ip address 10.0.40.2 255.255.255.0
standby version 2
ip address 10.0.50.2 255.255.255.0
standby version 2
ip address 20.0.0.3 255.255.255.0
duplex auto
speed auto
standby version 2
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
the " show standby brief " command output
R1#show standby brief
                     P indicates configured to preempt.
Interface   Grp  Pri P State    Active          Standby         Virtual IP
Fa0/1       1    100   Active   local           20.0.0.3        20.0.0.1
            10   100   Active   local           10.0.10.2       10.0.10.1
            20   100   Active   local           10.0.20.2       10.0.20.1
            30   100   Active   local           10.0.30.2       10.0.30.1
            40   100   Active   local           10.0.40.2       10.0.40.1
            50   100   Active   local           10.0.50.2       10.0.50.1
R1#exit
R2#sh standby brief
Fa0/1       1    100   Standby  20.0.0.4        local           20.0.0.1
            10   100   Standby  10.0.10.3       local           10.0.10.1
            20   100   Standby  10.0.20.3       local           10.0.20.1
            30   100   Standby  10.0.30.3       local           10.0.30.1
            40   100   Standby  10.0.40.3       local           10.0.40.1
            50   100   Standby  10.0.50.3       local           10.0.50.1
R2#exit
8 Replies 8
milan.kulik
Level 10
Level 10
are you able to Ping the physical IP address of the other ourter?
I.e., to Ping 10.0.10.2 from R1?
And to Ping 10. 0.10.3 from R2?
When you issue sh arp
on your router, do you see the entries for the other router physical IP address?
And on R2, do you see the ARP entry for the virtual IP address?
Best regards,
Milan
yes i am able to ping the physical ip address one router from the others . but i cannot ping the virtual ip
the show arp cmd output is given below
R1#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.10.1               5   0000.0C9F.0000  ARPA   FastEthernet0/0.1
Internet  10.0.10.2               4   00D0.97BA.C401  ARPA   FastEthernet0/0.1
Internet  10.0.20.1               5   0000.0C9F.0000  ARPA   FastEthernet0/0.2
Internet  10.0.20.2               3   00D0.97BA.C401  ARPA   FastEthernet0/0.2
Internet  10.0.30.1               3   0000.0C9F.0000  ARPA   FastEthernet0/0.3
Internet  10.0.30.2               3   00D0.97BA.C401  ARPA   FastEthernet0/0.3
Internet  10.0.40.1               5   0000.0C9F.0000  ARPA   FastEthernet0/0.4
Internet  10.0.50.1               5   0000.0C9F.0000  ARPA   FastEthernet0/0.5
Internet  10.0.50.2               3   00D0.97BA.C401  ARPA   FastEthernet0/0.5
Internet  10.0.50.5               5   0050.0F3E.8942  ARPA   FastEthernet0/0.5
Internet  20.0.0.1                5   0000.0C9F.F001  ARPA   FastEthernet0/1
Internet  20.0.0.3                1   00D0.97BA.C402  ARPA   FastEthernet0/1
Internet  20.0.0.4                -   0060.47D9.8B02  ARPA   FastEthernet0/1
R1#ping 10.0.40.2
R2#show arp
Internet  10.0.10.1               8   0000.0C9F.0000  ARPA   FastEthernet0/0.1
Internet  10.0.10.3               8   0060.47D9.8B01  ARPA   FastEthernet0/0.1
Internet  10.0.20.3               8   0060.47D9.8B01  ARPA   FastEthernet0/0.2
Internet  10.0.30.1               10  0000.0C9F.0000  ARPA   FastEthernet0/0.3
Internet  10.0.30.3               8   0060.47D9.8B01  ARPA   FastEthernet0/0.3
Internet  10.0.40.3               2   0060.47D9.8B01  ARPA   FastEthernet0/0.4
Internet  10.0.50.1               4   0000.0C9F.0000  ARPA   FastEthernet0/0.5
Internet  10.0.50.3               7   0060.47D9.8B01  ARPA   FastEthernet0/0.5
Internet  10.0.50.5               9   0050.0F3E.8942  ARPA   FastEthernet0/0.5
Internet  20.0.0.3                -   00D0.97BA.C402  ARPA   FastEthernet0/1
R2#ping 10.0.10.1
If you shut down the uplink from the core to the active router, does the standby assume the role of the active for the HSRP groups?
Can you post the config for your core router?
Yes the standby  router becomes when the link between core switch and active get disconnected .
I can see the MAC addresses of virtual IPs are strange:
All of theam are
0000.0C9F.0000
But they should be
0000.0C9F.Fxxx
where the xxxx is the hex representation of the HSRP group number.
(I can see 0000.0C9F.F068 for group 104 on my router.)
Also the Age of the virtual IP address ARP entry should be - on the primary router (it's his own virtual MAC address, not received by ARP response).
Can you provide a complete sh standby command output from your routers (not just brief)?
Which IOS version are you running (possible bug in it)?
I'd also try to add  standby priority 110 on the primary router  interface just for sure.
Best regards,
Milan
The Output of show standby command is below
R1#show stand
R1#show standby
FastEthernet0/1 - Group 1 (version 2)
  State is Standby
    5 state changes, last state change 00:00:36
  Virtual IP address is 20.0.0.1
  Active virtual MAC address is unknown
    Local virtual MAC address is 0000.0C9F.F001 (v2 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.657 secs
  Preemption disabled
  Active router is 20.0.0.3
  Standby router is local
  Priority 100 (default 100)
  Group name is hsrp-Fa0/1-1 (default)
FastEthernet0/0.1 - Group 10 (version 2)
  State is Active
    10 state changes, last state change 00:09:59
  Virtual IP address is 10.0.10.1
  Active virtual MAC address is 0000.0C9F.0000
    Local virtual MAC address is 0000.0C9F.F00A (v2 default)
    Next hello sent in 1.066 secs
  Preemption disabled
  Active router is local
  Standby router is 10.0.10.2
  Group name is hsrp--10 (default)
FastEthernet0/0.2 - Group 20 (version 2)
  State is Standby
    9 state changes, last state change 00:10:06
  Virtual IP address is 10.0.20.1
    Local virtual MAC address is 0000.0C9F.F014 (v2 default)
    Next hello sent in 1.31 secs
  Preemption disabled
  Active router is 10.0.20.2
  Group name is hsrp--20 (default)
FastEthernet0/0.3 - Group 30 (version 2)
  State is Standby
    9 state changes, last state change 00:09:57
  Virtual IP address is 10.0.30.1
    Local virtual MAC address is 0000.0C9F.F01E (v2 default)
    Next hello sent in 0.869 secs
  Preemption disabled
  Active router is 10.0.30.2
  Group name is hsrp--30 (default)
FastEthernet0/0.4 - Group 40 (version 2)
  State is Active
    10 state changes, last state change 00:09:58
  Virtual IP address is 10.0.40.1
    Local virtual MAC address is 0000.0C9F.F028 (v2 default)
    Next hello sent in 1.096 secs
  Preemption disabled
  Standby router is 10.0.40.2
  Group name is hsrp--40 (default)
FastEthernet0/0.5 - Group 50 (version 2)
  State is Active
    9 state changes, last state change 00:09:50
  Virtual IP address is 10.0.50.1
    Local virtual MAC address is 0000.0C9F.F032 (v2 default)
    Next hello sent in 2.413 secs
  Preemption disabled
  Standby router is 10.0.50.2
  Group name is hsrp--50 (default)
R1#
R2#
R2#show stan
R2#show standby
  State is Active
    5 state changes, last state change 00:00:18
  Active virtual MAC address is 0000.0C9F.F001
    Next hello sent in 2.448 secs
  Preemption disabled
  Standby router is 20.0.0.4
  State is Standby
    10 state changes, last state change 00:10:11
    Next hello sent in 0.011 secs
  Preemption disabled
  Active router is 10.0.10.3
  State is Active
    8 state changes, last state change 00:01:55
    Next hello sent in 0.824 secs
  Preemption disabled
  Standby router is 10.0.20.3
  State is Active
    8 state changes, last state change 00:01:53
    Next hello sent in 0.741 secs
  Preemption disabled
  Standby router is 10.0.30.3
  State is Standby
    Next hello sent in 0.827 secs
  Preemption disabled
  Active router is 10.0.40.3
  State is Standby
    10 state changes, last state change 00:10:10
    Next hello sent in 1.146 secs
  Preemption disabled
  Active router is 10.0.50.3
R2#
tis is really strange:
I'd
1) enable HSRP preemption on your routers
2) check other Cisco devices ( L3 switches) for HSRP configuration.
It could be there is HSRP v1, e.g., configured somewhere using the same IP addresses?
Best regards,
Milan
I agree with Milan that this is very strange. I also believe that it explains the problem in ping to the virtual address. From a previous post in this thread we can see that the response to ARP for the various virtual addresses always returns this MAC address  0000.0C9F.0000   but this is not the local virtual MAC. So the ping is using  0000.0C9F.0000   and the interfaces do not respond because they do not believe that it is their MAC.
Rick
Rick
