Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
HSRP Virtual ip not able to ping
Hai ,
   I am practising HSRP lab with 3 routers . I am going to create one standby group which  virutal ip 20.0.0.1 /24 ,the physical interface ip's are below 10.0.0.1 /24
10.0.0.2 /24
10.0.0.3 /24 .
Will my topology works .
find the attachment for full topology view .
1 ACCEPTED SOLUTION
You want the VIP and router IP's to be in different subnets? I'm affraid that won't work.
Hi Mohammed,
The HSRP VIP needs to be in the same subnet at the real router IP's.
I suggest changing the configuration so that the HSRP VIP is: 10.0.0.4 /24
the default route for R5 should then be set to:
ip route 0.0.0.0 0.0.0.0 10.0.0.4
cheers,
Seb.
Hai Seb,
      yes i tried with that and it works .  But  is there any trick  for making my topology works .
Then Fine Seb Rupik . Thanks
225
