Community Member
HSRP with Four L3 Switches
Can you run HSRP with four L3 switches
(1 active and 3 standbys)? How can I load balance between them? I'm assuming that that a routed connection would be required between the L3 switches correct?
thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: HSRP with Four L3 Switches
David
For HSRP/GLBP to work the switches need L2 adjacency. You can connect up your switches with L3 if you want but then if the switches only interconnect via L3 then HSRP/GLBP will not work.
Jon
David
You can run HSRP across 4 switches if you want although the switches would need to be interconnected with a L2 link and not a routed connection as HSRP packets are contained with vlans.
If you wanted to load balance you could use MHSRP but this is not very flexible compared to GLBP. GLBP would be the choice if you wanted to load balance. Again you would need L2 connectivity between your switches -
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_glbp.html
Jon
Community Member
Hi Jon,
just to understand it clearly. I would need a trunk connection not a routed connection?
Strange I was told by cisco that I could do layer 3 and not worry about layer 2. Very confusing.
David
Jon
You can certainly run HSRP across 4 switches. All you need to make sure is that the HSRP priorities are set properly on all the routers and they all are preempting.
I totally agree with Jon to use GLBP instead of HSRP if you want to loadbalance across them
Narayan
636
