Community Member
HSRP
Does anyone know if HSRP will work between 2 4506's that one has a SupV and one has a Sup6 engine?
3 ACCEPTED SOLUTIONS
Re: HSRP
Sure, if they are running L3 software.
HTH,
jerry
Hall of Fame Super Blue
Re: HSRP
Just to expand on Jerry's answer. HSRP does not care about the physical device as long as there is L2 adjacency between the 2 devices. So you can run HSRP between a 4500 and and a 6500, a 4500 and a 2800 router etc...
Jon
Re: HSRP
It will work without any problem !!
Ganesh.H
Re: HSRP
HTH,
jerry
Re: HSRP
Jon
Re: HSRP
Ganesh.H
252
