08-29-2008 08:23 PM - edited 03-06-2019 01:05 AM
Hi, when i try loggin by HTTPS on a router i have next errors.
%HTTPS: http ssl get context fail (-41104)
HTTP: ssl get context failed (-40407)
I have a 2821 router with
c2800nm-advipservicesk9-mz.124-15.T1.bin ios
Can anybody help me?
09-01-2008 05:26 AM
Try the following:
Router(config)#crypto key zeroize rsa
Router(config)#crypto key generate rsa
How many bits in the modulus [512]: 1024
% Generating 1024 bit RSA keys ...[OK]
09-01-2008 05:35 AM
it isn't help
09-01-2008 05:47 AM
If you have ip http secure-client-auth in your config, try removing it and then https again.
09-01-2008 11:19 AM
it doesn't work too
09-01-2008 12:07 PM
try to add these on your router:
Router(config)#username
Router(config)#ip http authentication local
Router(config)#line vty 0 4
Router(config-line)#login local
Router(config-line)#transport input ssh
privilege 15 allows you to configure your router. also, check if you IOS supports crypto functionality
09-01-2008 12:09 PM
i forgot to add this:
Router(config)#ip http secure-server
this command enables https access on the router
09-01-2008 11:20 PM
ssh 1.5 work correct.
of course i know about "ip http secure-server" command.
10-20-2012 02:25 PM
i know this is very old topic but any lick to solve it ?
12-03-2012 01:29 PM
hi,
the solution is easy and gave it above:
you have to generate key but 1024 not 512 this one is to SSH1.5.... i checked it a few minutes ago
01-11-2017 01:51 AM
To fix it I do the folowing :
(conf)#crypto key zeroize rsa
(conf)#ip http secure-server
Try again my connexion to ssl server and ... it's work like a charm ;)
After I create a new rsa key (1024)
(conf)#crypto key generate rsa modul 1024
Try ssh and https, work together now ;)
