Community Member
Hub Connectivity in Cisco 6500 IOS and CAT OS switches
We have lot of hubs connected in our cisco switches, planning to remove everything and replacing with L2 swithces, instead of physical check, is there any option to check the switches by logging in through telnet, any specific commands.
normally if there is any specific mac address, I can check it with sh mac-address dy int <>, now in this case , i dont have any specific mac.
Pls let me know if there is any solution for the same.
1 REPLY
Purple
Re: Hub Connectivity in Cisco 6500 IOS and CAT OS switches
Not that I know of if you don't have a mac and the hubs are unmanaged.
93
