Community Member
HWIC-4ESW in 2801, can't get working....
I have placed a hwic-4esw in my 2801.
I've created a subinterface and assigned that switchport to that vlan. I have then connected it to my 3750. I can see the link in cdp. I can even see the mac of the hwic-4esw in my 3750 mac table, but nothing more than that. I've attached the configs.
1 ACCEPTED SOLUTION
Re: HWIC-4ESW in 2801, can't get working....
no interface FastEthernet0/1.75
interface Vlan 75
description DMZ
ip address 10.10.75.22 255.255.255.0
no ip redirects
ip unreachables
no ip proxy-arp
no cdp enable
Community Member
hi,
if You want connect DMZ to port on HWIC-4ESW You must setup interface VLAN 75 with IP ADDRESS. Interface FastEthernet 0/1.75 is part of trunk on FastEthernet 0/1?
regards
romek
interface Vlan 75
description DMZ
no ip redirects
ip unreachables
no ip proxy-arp
no cdp enable
Purple
Get rid of the subinterface and create the following . Put that switchport into vlan 75.
Sorry didn't see the previous post which said the same thing!!
interface vlan 75
description DMZ
encapsulation dot1Q 75
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
295
