HWIC-4SHDSL-E Ethernet0/1/0 continuously up and down
Hi all, recently deployed a Pair of Cisco 1921 with HWIC-4SHDSL-E  in Slot 0 at both ends Cpe and CO. Below is a snapshot of the configuration from the CO end. The roles are stricttly at Layer 2. However, the link always keep up and down and I have replaced both end to end 1921 but the issue still occur ? Anyone has any idea what is the problem ?
controller SHDSL 0/1/0
 termination co
 dsl-group pairs  0 efm-bond
    shdsl rate 512
 description WAN
ip tcp selective-ack
ip tcp path-mtu-discovery
bridge irb
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description LAN
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Ethernet0/1/0
 description WAN
 no ip address
 load-interval 30
 bridge-group 1
interface BVI1
 description LAN
 ip address 172.20.209.155 255.255.255.0
bridge 1 protocol ieee
bridge 1 route ip
Jul 18 21:18:37 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 21:18:38 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to down
Jul 18 21:18:39 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to down
Jul 18 21:19:40 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 18 21:19:40 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 21:19:42 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to up
Jul 18 21:19:43 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to up
Jul 18 21:49:30 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 21:49:31 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to down
Jul 18 21:49:32 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to down
Jul 18 21:50:32 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 18 21:50:32 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 21:50:34 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to up
Jul 18 21:50:35 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to up
Jul 18 22:07:20 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 22:07:21 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to down
Jul 18 22:07:22 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to down
Jul 18 22:08:23 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 18 22:08:23 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 22:08:25 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to up
Jul 18 22:08:26 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to up
Jul 18 22:12:37 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 22:12:38 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to down
Jul 18 22:12:39 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to down
Jul 18 22:13:40 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 18 22:13:40 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 22:13:42 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to up
Jul 18 22:13:43 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to up
Jul 18 22:17:40 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 22:17:41 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to down
Jul 18 22:17:42 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to down
Jul 18 22:18:42 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 18 22:18:42 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 18 22:18:44 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to up
Jul 18 22:18:45 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to up
Jul 19 00:07:45 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 19 00:07:46 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to down
Jul 19 00:07:47 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to down
Jul 19 00:08:47 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 19 00:08:47 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 19 00:08:49 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to up
Jul 19 00:08:50 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to up
Jul 19 06:01:13 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 19 06:01:14 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to down
Jul 19 06:01:15 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to down
Jul 19 06:02:15 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 19 06:02:15 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 19 06:02:16 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 19 06:03:19 CCT: %SHDSL_EFM-5-DSLGROUP_UPDOWN: SHDSL dsl-group state changed to up.
Jul 19 06:03:19 CCT: %SHDSL_EFM-5-EFM_BOND_LINK_RATE_CHANGE: SHDSL EFM Bonding Group Link(0) bandwidth is changed.
Jul 19 06:03:21 CCT: %LINK-3-UPDOWN: Interface Ethernet0/1/0, changed state to up
Jul 19 06:03:22 CCT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1/0, changed state to up
  • LAN Switching and Routing
Hi,I have not worked with
I have not worked with this card myself but there is a very nice HowTo document here:
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/GSHDSL_EFM_ATM_HWICS.html
According to that document, you seem to be missing the mode efm command in the controller configuration, and it appears that the default setting for the mode is ATM, not EFM, so that may be in conflict with the subsequent definition of the dsl-group that tries to use EFM bonding. In addition, you are trying to use the EFM bonding using only one wire pair - which is kind of useless, as there is nothing to bond this one pair with. You could also try removing the efm-bond keyword from the dsl-group configuration.
If following these suggestions and the document above does not help please try posting the complete output of show controllers shdsl 0/1/0 detailed. It would also be interesting to know if the routers actually got connected succesfully if they were cabled back-to-back with a short Ethernet cable, to remove any suspicion that the line itself is faulty.
Looking forward to your response!
Best regards,
Peter
Dear,I have two location with
Dear,
I have two location with 2901 router. now customer would like go for point to point leased line connection with the speed of 14mbps.From service provider side , they are going to provide RJ45 connector to terminate into the router. need suggestion to chose the HWIC card?? Can I use the below mentioned one?
HWIC-4SHDSL-E
Please suggest.
81
