Webcast-Catalyst9k
hwic-d-9esw-poe vlan problem
I have a switching module that is installed in a 2811 router. I am serving DHCP from the router and using access vlan 40 and voice vlan 400 for the phones. When the switching module ports are in trunking mode, the phones work fine but when a PC is plugged into the PC port of the phone, the PC's cannot access vlan 40 for data. When trunking is turned off on the ports and the PC's are plugged directly into the switch, they work fine. Does anyone have any experience with these switching modules that install in the router?? Help...Thanks in advance!
Purple
Re: hwic-d-9esw-poe vlan problem
What is the port config for the switch module? Do you need to trunk to the phones , a lot of times you set it up as a normal acces port and configure a voice vlan on the port too .
Originally I had it set to:
switchport mode trunk
switchport access vlan 40
swithcport voice vlan 400
mls qos trust cos
spanning-tree portfast
Then I tried:
switchport trunk native vlan 40
switchport voice vlan 400
mls qos trust cos
With this switching module, the only way it would work is by turning on trunking on the switchport. I have never had to do it this way in the past but this module is doing something funky!
399
